Baseboard Heater Questions - Electrical - DIY Chatroom Home Improvement Forum
Old 02-12-2013, 06:39 PM   #1
Baseboard heater questions
I would like to wire 2 baseboard heaters in my basement. They are both 240v heaters. 1 is a 1500 watt and the other is a 500 watt. Each will have their own thermostat.
I currently have 100amp service to the house. There main panel is full.
A load center was added for a dishwasher.
My plan was to remove the current load center for the dishwasher and replace it with an 8 circuit, 4 place 125amp load center. I would then wire both heaters using 14-2 wire to the same 15amp double pole circuit breaker. I would move the current 20 amp circuit for the dishwasher to the new load center and there would then be 1 open spot in the new panel.
Does this sound ok? Are my wire sizes and breakers the right size? According to what I calculated I think it will work, but not sure when having different thermostats. Also what might happen if I were to add another 500 watt heater down the road?
Any help, confirmation, or guidance is highly appreciated.
I can take better pics if need be.
[IMG]ftp://cis.bismarckstate.edu/frohlich/Relay/all%20panels.jpg[/IMG]
frohboy33 is offline   Reply With Quote
Old 02-12-2013, 06:48 PM   #2
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
Can you post a picture inside the panel? What size wire and breaker is feeding the dishwasher panel now?
With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Old 02-12-2013, 07:01 PM   #3
I can't tell what size wire it is by looking at it, sorry. There isn't any labeling on the part that I can see. The breaker for the dishwasher is a 20amp breaker. The wire size to the dishwasher is 12-2.
Baseboard heater questions-2013-02-12_17-52-11_977.jpg   Baseboard heater questions-2013-02-12_17-52-32_641.jpg   Baseboard heater questions-2013-02-12_17-53-00_34.jpg
Old 02-12-2013, 07:06 PM   #4
rrolleston's Avatar
Originally Posted by frohboy33 View Post
I can't tell what size wire it is by looking at it, sorry. There isn't any labeling on the part that I can see. The breaker for the dishwasher is a 10amp breaker. The wire size to the dishwasher is 12-2.
What breaker turns off the power to that panel?
Old 02-12-2013, 07:07 PM   #5
jbfan's Avatar
Rewards Points: 246
That's not a 10 amp breaker.
The size of the breaker is on the handle, and will be 15 or 20.
The wire looks to be #6.
What size breaker feeds this small panel?
jbfan is online now   Reply With Quote
Old 02-12-2013, 07:10 PM   #6
rrolleston's Avatar
If the wire is stranded it's possibly 8 or 6. But I would read the jacket to be sure.
Old 02-12-2013, 07:22 PM   #7
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Who ever installed the subpanel installed it incorrectly/illegally. The grounds and neutrals have to be separated.
Old 02-12-2013, 07:28 PM   #8
Sorry about that its a 20amp breaker not a 10.
From what I can see there is no breaker that feeds the small panel. The small panel is connected directly to the main power from the main panel.
The previous home owner I am assuming wired this himself. That is probably why it is incorrect/illegal. What should I do about that?
Old 02-12-2013, 07:32 PM   #9
rrolleston's Avatar
You can't use this panel it was installed incorrectly and should be removed by a qualified electrician.
Old 02-12-2013, 07:32 PM   #10
k_buz's Avatar
They make Pushmatic tandem breakers. I don't know if your panel is rated for them and they are not cheap, but that is one suggestion.
The other is contact an electrical contractor for a quote on a new service.
Old 02-12-2013, 07:33 PM   #11
rrolleston's Avatar
It's possible that there are a lot of illegal gremlins inside that panel.
I would be really interested to see the inside of the main panel.
Old 02-12-2013, 07:38 PM   #12
I'm scared! I'll take a pic and post it up in a few.
Old 02-12-2013, 07:52 PM   #13
Here are inside of the main panel pics.
Baseboard heater questions-2013-02-12_18-46-27_180.jpg   Baseboard heater questions-2013-02-12_18-46-39_868.jpg
Old 02-12-2013, 08:00 PM   #14
rrolleston's Avatar
Many double taps in there. I would not use that panel the way it is. Looks like you could benefit from a panel upgrade so you have more room.
Old 02-12-2013, 08:03 PM   #15
MarginallyQualified
Rewards Points: 2,464
A service upgrade too.
Two plumbing questions: Water heater drain and expansion tank. TexasPenguin Plumbing 10 10-30-2012 02:35 PM
replacing baseboard heater under receptacle - doh! rkg Electrical 2 04-28-2012 01:49 AM
Removing baseboard heater in bathroom frankm1960 Electrical 4 11-25-2011 11:38 AM
Running lines to baseboard heater using Pex. RyanD Plumbing 5 07-05-2009 08:32 AM
Tankless water heater questions shadango Plumbing 8 11-12-2008 08:10 PM
