-   -   Baseboard heater questions (http://www.diychatroom.com/f18/baseboard-heater-questions-171802/)
frohboy33 02-12-2013 06:39 PM
1 Attachment(s)
I would like to wire 2 baseboard heaters in my basement. They are both 240v heaters. 1 is a 1500 watt and the other is a 500 watt. Each will have their own thermostat.
I currently have 100amp service to the house. There main panel is full.
A load center was added for a dishwasher.
My plan was to remove the current load center for the dishwasher and replace it with an 8 circuit, 4 place 125amp load center. I would then wire both heaters using 14-2 wire to the same 15amp double pole circuit breaker. I would move the current 20 amp circuit for the dishwasher to the new load center and there would then be 1 open spot in the new panel.
Does this sound ok? Are my wire sizes and breakers the right size? According to what I calculated I think it will work, but not sure when having different thermostats. Also what might happen if I were to add another 500 watt heater down the road?
Any help, confirmation, or guidance is highly appreciated.
I can take better pics if need be.
[IMG]ftp://cis.bismarckstate.edu/frohlich/Relay/all%20panels.jpg[/IMG]
rrolleston 02-12-2013 06:48 PM
Can you post a picture inside the panel? What size wire and breaker is feeding the dishwasher panel now?
frohboy33 02-12-2013 07:01 PM
3 Attachment(s)
I can't tell what size wire it is by looking at it, sorry. There isn't any labeling on the part that I can see. The breaker for the dishwasher is a 20amp breaker. The wire size to the dishwasher is 12-2.
rrolleston 02-12-2013 07:06 PM
Originally Posted by frohboy33 (Post 1116066)
I can't tell what size wire it is by looking at it, sorry. There isn't any labeling on the part that I can see. The breaker for the dishwasher is a 10amp breaker. The wire size to the dishwasher is 12-2.
What breaker turns off the power to that panel?
jbfan 02-12-2013 07:07 PM
That's not a 10 amp breaker.
The size of the breaker is on the handle, and will be 15 or 20.
The wire looks to be #6.
What size breaker feeds this small panel?
rrolleston 02-12-2013 07:10 PM
If the wire is stranded it's possibly 8 or 6. But I would read the jacket to be sure.
k_buz 02-12-2013 07:22 PM
Who ever installed the subpanel installed it incorrectly/illegally. The grounds and neutrals have to be separated.
frohboy33 02-12-2013 07:28 PM
Sorry about that its a 20amp breaker not a 10.
From what I can see there is no breaker that feeds the small panel. The small panel is connected directly to the main power from the main panel.
The previous home owner I am assuming wired this himself. That is probably why it is incorrect/illegal. What should I do about that?
rrolleston 02-12-2013 07:32 PM
You can't use this panel it was installed incorrectly and should be removed by a qualified electrician.
k_buz 02-12-2013 07:32 PM
They make Pushmatic tandem breakers. I don't know if your panel is rated for them and they are not cheap, but that is one suggestion.
The other is contact an electrical contractor for a quote on a new service.
rrolleston 02-12-2013 07:33 PM
It's possible that there are a lot of illegal gremlins inside that panel.
I would be really interested to see the inside of the main panel.
frohboy33 02-12-2013 07:38 PM
I'm scared! I'll take a pic and post it up in a few.
frohboy33 02-12-2013 07:52 PM
2 Attachment(s)
Here are inside of the main panel pics.
rrolleston 02-12-2013 08:00 PM
Many double taps in there. I would not use that panel the way it is. Looks like you could benefit from a panel upgrade so you have more room.
TarheelTerp 02-12-2013 08:03 PM
A service upgrade too.
