Old 12-01-2007, 12:36 AM   #1
Default Baseboard Heater: Can I wire it to plug into an AC recepticle?
I've got a baseboard heater that I am not using in 1 room and I'd like to move it into another. However, instead of rewiring the room or purchasing a new space heater.....I thought I could just wire it to ac cord so that I can store it away in the fall, spring and summer.
I know that I will void the manufacture warranty, but I was wondering:
  • Is this safe idea? Guess who is unsure, my wife. Go figure.
  • What parts do I need and am I likely to find what I need at Home Depot or my local hardware store?
I've changed recepticles before and twisted speaker wire together. That is pretty much the extent of my electrical experience.
BTW- The outlet I want to plug into is 15 amp. Voltage.....not exactly sure. I would think 120, but my breaker isn't labled. Its only 1 switch, not a double switch (is that were 220 ie "2 20 amps" comes from?).
Here are the electrical details regarding my baseboard heater:
Model Number: 2F500-1A
30" Baseboard
Watts 120V: 500
Amps 120V: 4.17
Weight: 6 LBS
Thanks!
JBiz is offline   Reply With Quote
Old 12-01-2007, 12:47 AM   #2
Union Electrician
goose134's Avatar
I know that this will seem like a drag but I think that voiding the warrenty on the heater wouldn't be prudent. Suppose something bad DOES happen and a fire starts. Insurance is not going to look kindly on a modified appliance that started it. Long story short, code says that if a device is not listed for a use, you can't use it. It's a small enough unit that a comparable one that IS listed wouldn't be hard to get. Hope that helps. Sorry for the bad news.
goose134 is offline   Reply With Quote
Old 12-01-2007, 02:57 AM   #3
" Euro " electrician
if this heater is not used anymore and it is on delcated circuit then a good chance you can used for the A/C but it will only work if the thermosat is on the heater itself but with wall thermoast it can be doable but if you no longer want the heater you have to remove the thermast and wirenutted them and put in blank cover but you can not bury the box ditto with the splices in the wall.
some case there is a asscorey kit you can add on to the baseboard heater like this [ you may have to scroll down a little then you get the idea with it ]
http://www.cadetco.com/show_product.php?prodid=1004
this will get you some idea with it but before you do it make sure if this heater is delcated circuit [ trust me you will understand why in a min ]
becaue the window shaker [ window mounted air conding] will useally take more than 7 amp of power easly
Merci, Marc
Old 12-01-2007, 10:42 AM   #4
Merci, Marc
Does a off-high constitute as a thermostat? Seems like more of a setting to me, but it was listed as an accessory item (BTF2A) on the page you linked. My baseboard heater has this on it:
http://www.cadetco.com/support/products/x_large/1004c.jpg
Secondly, I missed why it is important to have a dedicated circuit. If it is only drawing 4.17 amps....why can't it share a circuit with a hallway light and an outlet using a lamp/cd player?
Thanks again,
JBiz
More On This Topic
Pull the dash piece. Behind here you have the crossover for the stereo system. Let's move that out of the way. You have your air conditioning components. Here is your heater core. Access in the heater core wiring is right here in this harness. But... Read More »
A space heater can save money on gas and electric bills because it heats only a small area and efficiently converts almost all of its energy into heat. However, heaters can pose a serious danger from fire and toxic air pollution. Reduce these risks by... Read More »
Depending on where you live in the United States, you may encounter high monthly bills for heating your home. Many homes in warmer climates are built with wide windows and open floor plans, so unexpected low temperatures often result in cold, drafty... Read More »
Choosing a Fish Tank Heater
Choosing a Fish Tank Heater by Expert Village
Okay, besides filtration, your heat unit is most important, too and as with any other thing you purchase, you pretty much get what you pay for. This lower end type of heater will do the job, but it presents some problems in that circuitry is not as good... Read More »
This is an easy project that not only benefits the environment, but saves you money on your power bills. Having your water heater properly insulated results is less heat loss. So all the energy is spent on heating the water you will use, not wasted in... Read More »
Using a thermostat/relay to control baseboard heater perpetual98 Electrical 10 06-08-2009 01:57 AM
Water heater problem bear1957 Plumbing 23 11-01-2007 05:53 PM
Baseboard heater Help! jweinstock Electrical 6 10-28-2006 06:01 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 12:31 PM
help! - how do I wire a polarised USA plug?? Unregistered Electrical 1 12-22-2003 08:27 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
