Baseboard Heater - Electrical - DIY Chatroom Home Improvement Forum
Old 03-14-2008, 01:48 AM   #1
Baseboard Heater
Hello All, how do you install the hookup at rough-in stage for this baseboard heater?
http://www.lowes.com/lowes/lkn?actio...426&lpage=none
I have never installed one before so am guessing it does not take a regular outlet box?
matrix733 is offline   Reply With Quote
Old 03-14-2008, 07:43 AM   #2
47_47's Avatar
Rewards Points: 44
Are you using a hardwired thermostat or the remote?
47_47 is offline   Reply With Quote
Old 03-14-2008, 11:22 AM   #3
You'll need to purchase the integral thermostat as well, or a wall mounted 240 volt thermostat. These BB units are hardwired directly to the cable from the wall.
LawnGuyLandSparky is offline   Reply With Quote
Old 03-14-2008, 08:37 PM   #4
It will be a wall mounted thermostat 22amps 240v controlling 4 units on a 20amp breaker. A cable clamp will be used to connect the wire directly to the unit so the wire sticks out the finnish wall till the unit is installed?
Thanks for your help.
Old 03-17-2008, 07:48 AM   #5
47_47's Avatar
Rewards Points: 44
Yes, that's how to do it. Just make sure to mark your whites as hot and there are no electrical outlets placed above these heaters.
Using a thermostat/relay to control baseboard heater perpetual98 Electrical 10 06-08-2009 12:57 AM
Electric Baseboard Heater shawnmichaelthomas Electrical 37 03-10-2008 05:32 PM
Baseboard Heater: Can I wire it to plug into an AC recepticle? JBiz Electrical 3 12-01-2007 09:42 AM
Baseboard heater Help! jweinstock Electrical 6 10-28-2006 05:01 PM
Periodic release from (I think) the T&P valve on the water heater alexz Plumbing 3 08-15-2006 11:31 AM
