Baseboard Heat - Electrical - DIY Chatroom Home Improvement Forum
Old 04-18-2009, 02:58 AM   #1
Baseboard heat
Hope I did this right!
I wired 12-2 with ground.
from my Main panel to 3 separate thermostats.
From each thermastat 12-2 with ground to each baseboard heater.
Now I can just throw in the double pole thermostats and a 240 volt 20 amp breaker everything is cool (I mean hot) right?
I will be using 1 1500 watt
and 2 1000 watt heaters.
Does the 80 percent rule apply to this?
240v X20 amps = 4800 watts.
80% of 4800 watts = 3840 watts usable.
Thanks people
luweee is offline   Reply With Quote
Old 04-18-2009, 07:52 AM   #2
Remodeling Contractor
yes the rule applies, Yes the wiring is correct
Help with bleeding baseboard heat system robinswendy HVAC 1 12-13-2008 04:04 AM
Baseboard Heat monk4270 Plumbing 2 12-07-2008 06:19 PM
Baseboard heat not heating house.. Please help wadams HVAC 2 12-06-2007 08:12 AM
Remove baseboard heat? Patrick B HVAC 6 04-11-2006 04:12 PM
baseboard heat upstairs not working TraceyLee HVAC 1 10-23-2005 05:47 PM
