Old 03-04-2011, 07:49 PM   #1
Base board heaters, thermostat, power
Hi, I replaced the baseboard heater in my downstairs computer room, and there was power to it. Then when I went to turn the thermostat on...no heat! So not being electrical 'savvy', I bought a new thermostat, and upon disconnecting the old thermostat, I touched the two wires from the back of the thermostat, with a 'reader', and there was no current! All other baseboard heaters in the downstairs area work, and this one also, as I checked it at another source,..What am I missing here?
Syd
scoggy is offline   Reply With Quote
Old 03-04-2011, 08:09 PM   #2
I=E/R
a7ecorsair's Avatar
How do you know it had power? Do you know if the heater is operating on 240 volts? Does the thermostat you mention control just this heater or does it control others as well?
a7ecorsair is offline   Reply With Quote
Old 03-04-2011, 08:39 PM   #3
The 'test' lamp showed there was power to the heater. Yes 240 V, Yes only this one.
Syd
Old 03-04-2011, 08:48 PM   #4
I=E/R
a7ecorsair's Avatar
Your thermostat is a line voltage one correct? Does it have two wires or four wires and what color are they?
Old 03-04-2011, 09:00 PM   #5
The lines that come out of the wall socket are both..black, and the ones on the thermostat, are red and black.
Syd
Old 03-04-2011, 09:23 PM   #6
I=E/R
a7ecorsair's Avatar
You only have two wires coming from the wall?
Old 03-04-2011, 09:30 PM   #7
Yes, just 2 black wires
Old 03-04-2011, 09:44 PM   #8
I=E/R
a7ecorsair's Avatar
Is the thermostat mounted on the baseboard itself? If so, the two blacks from the wall go to the two reds on the thermostat and the two blacks on from the thermostat go to the two wires on the heater.
Old 03-04-2011, 10:16 PM   #9
There are just 2 BLACK wires that come out of the wall where the 'original' thermostat was. This 'switch is about 30 feet away from the Baseboard heater!
As I stated earlier, I am having problems..'understanding' what you say!
Syd
No, the thermostat is not 'mounted' on the heater, it is on the wall
Old 03-04-2011, 10:21 PM   #10
I=E/R
a7ecorsair's Avatar
Has this heater worked in the past?
Is this wiring run in conduit between the thermostat and the heater?
weathertron Mecury Thermostat VickiL HVAC 4 02-06-2011 05:32 PM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 07:43 PM
Newly installed Thermostat doesn't power on falcon753 HVAC 17 10-28-2008 09:53 AM
Maximum base board loop length Mike Warner HVAC 1 05-01-2008 12:48 AM
Installing deck ledger board over foam board? RickT Building & Construction 5 11-06-2006 11:50 PM
