-   -   Base board heaters, thermostat, power (http://www.diychatroom.com/f18/base-board-heaters-thermostat-power-97257/)
scoggy 03-04-2011 07:49 PM
Hi, I replaced the baseboard heater in my downstairs computer room, and there was power to it. Then when I went to turn the thermostat on...no heat! So not being electrical 'savvy', I bought a new thermostat, and upon disconnecting the old thermostat, I touched the two wires from the back of the thermostat, with a 'reader', and there was no current! All other baseboard heaters in the downstairs area work, and this one also, as I checked it at another source,..What am I missing here?
Syd:confused1::confused1::confused1:
a7ecorsair 03-04-2011 08:09 PM
How do you know it had power? Do you know if the heater is operating on 240 volts? Does the thermostat you mention control just this heater or does it control others as well?
scoggy 03-04-2011 08:39 PM
Baseboard heaters
The 'test' lamp showed there was power to the heater. Yes 240 V, Yes only this one.
Syd
a7ecorsair 03-04-2011 08:48 PM
Your thermostat is a line voltage one correct? Does it have two wires or four wires and what color are they?
scoggy 03-04-2011 09:00 PM
Base board heaters
The lines that come out of the wall socket are both..black, and the ones on the thermostat, are red and black.
Syd
a7ecorsair 03-04-2011 09:23 PM
You only have two wires coming from the wall?
scoggy 03-04-2011 09:30 PM
Baseboard heaters
Yes, just 2 black wires
a7ecorsair 03-04-2011 09:44 PM
Is the thermostat mounted on the baseboard itself? If so, the two blacks from the wall go to the two reds on the thermostat and the two blacks on from the thermostat go to the two wires on the heater.
scoggy 03-04-2011 10:16 PM
Thermostat
There are just 2 BLACK wires that come out of the wall where the 'original' thermostat was. This 'switch is about 30 feet away from the Baseboard heater!
As I stated earlier, I am having problems..'understanding' what you say!
No, the thermostat is not 'mounted' on the heater, it is on the wall
a7ecorsair 03-04-2011 10:21 PM
Has this heater worked in the past?
Is this wiring run in conduit between the thermostat and the heater?
