Bare Grounding Pigtails? - Electrical - DIY Chatroom Home Improvement Forum
Old 05-27-2012, 06:25 AM   #1
Rewards Points: 135
Bare grounding pigtails?
I'm daisy chaining quad outlets in metal boxes. Do the lengths from the wirenut to each outlet and ground screw need to be stripped bare or can I keep the insulation on them? Is this always the case, or are there sometimes where bare/insulated is required?
And related, there will be 5 wires into the grounding wirenut,is there any way around this, I don't like the idea of having so many wires on one wirenut. I do have the proper size for it. Is there any way to help this stay secure other than just wrapping with electrical tape?
smata67 is offline   Reply With Quote
Old 05-27-2012, 06:58 AM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,274
The ground wire can be insulated as long as it is green. A properly installed wire nut does not need to be taped.
Coastal South Carolina
Old 05-27-2012, 07:27 AM   #3
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
You could use ONE set of longer pigtails and hit both devices, instead of each device having its own pigtail.... and please don't tape wire nuts on, it means you either didn't install them properly or don't have the correct size wire nut.
The Following 2 Users Say Thank You to stickboy1375 For This Useful Post:
Jim Port (05-27-2012), oh'mike (05-27-2012)
Need to know if my grounds and neutrals are connected right dorlow Electrical 185 01-15-2012 02:54 PM
Grounding sub-panel at pool house CraigMW Electrical 12 08-19-2011 10:08 AM
Wiring of bare copper wire in a light fixture Fleet_Foxes Electrical 5 07-16-2009 08:44 PM
Anyone want to take a shot at why #6 to attach antenna ground to breaker? Piedmont Electrical 44 01-08-2008 04:11 PM
NEC Question Jafsvcs Electrical 1 06-13-2007 05:45 PM
