Old 10-04-2008, 10:59 PM   #1
Bare Ground Wires
I have a very basic question about ground wires. I have two how-two books on electricity, and in the pictures one book shows ground wires as bare and the other book shows them with green insulation. Why is it okay to use bare ground wires inside an electrical box instead of insulated ones? I would think that bare ground wires could rub up against an electrical contact. And what would happen if a ground wire did touch an electrical contact?
MrBill_DIY is offline   Reply With Quote
Old 10-04-2008, 11:28 PM   #2
My License Ain't 4 Sale..
Bare Ground Wires
A short circuit would develop if a ground wire touches a live contact. I'm not exactly sure of the history of why wire manufacturers began making cables with a bare ground. I imagine it may be that they figured the boxes they were going in were all metal (at that time), and grounded, so it didn't matter if the ground was bare also. I'm sure it also costs a little more to insulate the ground. I would like to see that happen someday. But careful electricians tuck their wires neatly into the boxes so that no contact occurs.
At any rate, carelessness can cause a short with or without insulated grounds.
Old 10-04-2008, 11:30 PM   #3
Licensed electrician
Bare Ground Wires
If the bare is properly connected at the panel and comes in contact with an energized part it would trip the breaker.
Old 10-04-2008, 11:41 PM   #4
Bare Ground Wires
Basically the metal cases on *everything* electrical should be grounded, so no problem with a bare ground wire touching any metal case/box. Also it is less expensive to manufacture the wire.
Now if a bare ground wire were to contact a "hot" conductor, then this would trip the breaker*. Or if a "hot" wire were to contact a bare ground wire, then this would trip the breaker.
The best part of all this is if a hot wire (say in an appliance like a range) were to touch the metal case of the appliance, then this would trip the breaker. This is a neat feature about grounding. It will either trip the breaker or at least keep the "short" at "ground potential" so people are protected from being electrocuted.
As to wiring outlets, I like to connect/bend the ground wires so they will go to the back of the box when installing the outlet. Keep them away from the front sides of the box.
As for insulated green ground wires, you will see this on appliances with stranded wire cords where everything can be moved, dropped, twisted, etc. In this case you wouldn't want a ground wire to go flying around inside the appliance and possibly contacting a hot connection.
*Assuming everything is wired to modern code.
Billy_Bob is offline   Reply With Quote
Old 10-05-2008, 08:05 PM   #5
Bare Ground Wires
Thanks, that's good information. I've been trying to push the bare ground wires to the back of the electrical box as you said, to keep them away from the contacts on the receptacles.
This doesnt seem right. JoulesWinfield Electrical 27 07-26-2009 08:40 PM
Broken/missing ground wires? fw2007 Electrical 5 07-08-2008 10:54 AM
Subpanel feeder questions Silhanek Electrical 4 03-22-2007 07:30 PM
Bridging Ground wires. Duppy Electrical 13 01-17-2007 07:31 PM
