Ballasts - Electrical - DIY Chatroom Home Improvement Forum
Old 04-29-2009, 10:20 AM   #1
Ballasts
Do you technically need to be a licensed electrician to change a ballast in a commercial setting? In MN?
mjj84 is offline   Reply With Quote
Old 04-29-2009, 11:55 AM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 232
Depends on the state and local regulations where you live.
Old 04-29-2009, 12:06 PM   #3
Rewards Points: 80
Do you work there? If you do, change one. Turn off the switch or breaker first.
Old 04-29-2009, 08:32 PM   #4
" Euro " electrician
frenchelectrican's Avatar
the answer will say yes and no it depending on the local regulations and state regulations as well.
I know in State of Wisconsin typically say it must have electrician to do this unless you have qulified mantenace person on the premise { that can raise sore subject if not carefull }
In France it must be done by electrician { all areas }
Merci,Marc
Old 04-29-2009, 10:31 PM   #5
Every state I have worked in, if you own the property or have maintenance people you or they can do it, In some states there is no restrictions who can do it.
hayewe farm is offline   Reply With Quote
Recessed lighting, dimmer, compact fluerecents...anything special? gone_fishing Electrical 2 01-04-2009 08:35 PM
