Ballast Wiring, To And Neutral Wires. - Electrical - DIY Chatroom Home Improvement Forum
Old 03-03-2011, 05:04 PM   #1
Wek
Ballast wiring, to and neutral wires.
In order to wire a ballast to a lamp wire I have to connect the black (hot) wire to the smooth wire lamp and the white (neutral) to the ribbed wire lamp, right?
Wek is offline   Reply With Quote
Old 03-03-2011, 06:42 PM   #2
Rewards Points: 1,536
Yes, you would connect the white wire to the neutral, but there are probably other things you need to connect, such as lamp sockets. You will have to check the instructions and wiring diagram for that ballast.
The Following User Says Thank You to AllanJ For This Useful Post:
Wek (03-03-2011)
Old 03-03-2011, 07:03 PM   #3
Wek
For this model I just have to connect the ballast wire. The sockets were came already connected and all I had to do was mount them to the side.
3 Wire Set Up . . . Neutral Wire Tied to Ground Wires irishMonster Electrical 14 10-21-2010 08:20 AM
Sharing Neutrals on the same phase electro Electrical 30 08-12-2010 02:10 PM
Main disconnect neutral wiring Daniel Holzman Electrical 5 10-04-2009 01:36 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
Nuetral from feeder cable to main panel question? TW Lucas Electrical 14 05-08-2008 11:33 AM
