Ballast Replacement Question - Electrical - DIY Chatroom Home Improvement Forum
Old 03-28-2012, 09:27 PM   #1
ballast replacement question
I am trying to replace a ballast in my upstairs bathroom. The old one has two red, two blue, two yellow, a black and white.
The new one has black, white, one red and two blue. No yellow. How do I connect the new one?
Bradley C. is offline   Reply With Quote
Old 03-28-2012, 09:47 PM   #2
Julius793's Avatar
is the old ballast a 4 bulb? because i think the new ballast is a two bulb
Electricity will kill you if you give it a chance
Julius793 is offline   Reply With Quote
The Following User Says Thank You to Julius793 For This Useful Post:
LooseSCruz (03-28-2012)
Old 03-28-2012, 10:38 PM   #3
I concur with Julius, your description of the original sure sounds like a 4 lamp ballast. What does the new ballast say it's rated for and what does the wiring diagram look like? This info should be on the front of the ballast....but it sounds like you've just got the wrong one.
LooseSCruz is offline   Reply With Quote
Old 03-28-2012, 10:42 PM   #4
" Euro " electrician
frenchelectrican's Avatar
Either that and with older ballast that is rapid start format that is a common set up and when OP got the new ballast which it allready a electroque ballast the connection will be differnt.
To OP what bulb size are you refering to this and how many as well?
Also post the new ballast number if you can we can able guide ya along the way.
Merci,
Marc
Florescent ballast, commercial or residential? rjniles Electrical 183 05-13-2016 03:47 PM
ballast replacement T Wynn Electrical 4 01-01-2010 09:02 PM
Stair Tread Replacement Question Mikedks Flooring 6 07-14-2008 04:04 PM
Replacement window nailing fin question gortman Building & Construction 7 11-28-2006 07:33 AM
Trane Heat Pump tstat replacement with Honeywell prog - wiring question sep23 HVAC 2 10-20-2006 09:10 PM
