Ballast Question - Electrical - DIY Chatroom Home Improvement Forum
Old 12-29-2012, 08:44 PM   #1
Ballast Question
We have a light that the ballast has gone bad in that uses 2 CF26 bulbs. The Ballast is an ICF-2S26-H1-LD. I went to Home Depot and Lowes in search of one and they dont have an exact match but while I was there I picked up a RELB-2S40-N.
I wired it up the same and it works finw with no humming but is it safe to use a standard size ballast with the 40 watt output on the compact fluorescent 26 watt bulbs?
The size isn't an issue and will fit just fine.
custom2k11 is offline   Reply With Quote
Old 12-29-2012, 09:37 PM   #2
Electrical Contractor
kbsparky's Avatar
There should be a whole list of compatible bulbs that can be used on the replacement ballast.
Checking RELB-2S40-N does not include 26 watt bulbs.
While it may appear to work initially, such unauthorized use will probably result in premature ballast and/or bulb failure.
You can get the ICF-2s26 ballast at Amazon.
-KB
The Following 2 Users Say Thank You to kbsparky For This Useful Post:
custom2k11 (12-30-2012), NJMarine (12-30-2012)
Just a quick+easy question to pest control workers and/or owners...pls read..... jkls Pest Control 2 10-09-2012 10:53 PM
Venting over the range convection oven question johncle6023 HVAC 4 08-31-2012 08:30 PM
T8 vs. T12 Ballasts capt2 Electrical 22 05-15-2010 03:25 AM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
