Old 02-24-2011, 01:22 PM   #1
DIYer
Ballast/Lamp Efficiency
Is it better to go with a lower wattage light on a higher factor ballast, or a low factor ballast with a higher wattage light.
Such as 32 watt T8 with a low BF ballast of .75 vs 28 watt T8 on a normal .88 ballast?
The output should be about the same in both cases, so which is more efficient? Is one way going to cut the life?
Gigs is offline   Reply With Quote
Is it possible to maintain original window style and gain efficiency? toyarmy Remodeling 4 02-07-2011 02:12 PM
Hot Water Heater Efficiency? Chemist1961 Plumbing 2 12-11-2010 07:34 AM
High efficiency furnace size to use 2inch vent and intake SFX Group HVAC 4 11-07-2010 11:12 AM
Venting med. efficiency furnace and H2O heater thru wall? cbrc5eric Building & Construction 2 04-03-2010 12:07 AM
A/C efficiency frankeu HVAC 2 07-23-2008 05:46 AM
