Ballast For Flourescent Bulb - Electrical - DIY Chatroom Home Improvement Forum
Old 03-28-2012, 07:13 AM   #1
Ballast for flourescent bulb
Have old ballast burn out, it has black & white wire on one side a blue & red wire on other side, I took old ballast to electric supply store to get replacement, they have me a ballast with two blue & one red wire, told me cap off one blue wire! It worked for 30 minutes and light went out, burn the ballast, why?
chshininc is offline   Reply With Quote
Old 03-28-2012, 11:16 AM   #2
All ballasts have a wiring diagram on them. The colours aren't always the same. Put your old ballast beside your new one and check for the differences in the diagram. Rewire to the new ballast ignoring your existing wire colours but connecting the ballast leads to the lamp terminals as marked on the new wiring diagram.
fdiddy is offline   Reply With Quote
Old 03-28-2012, 11:28 AM   #3
Did you install a new bulb at the same time as the new ballast?
LooseSCruz is offline   Reply With Quote
Old 03-28-2012, 12:20 PM   #4
Yes, I did, actually owner went to lowes and bought two of the new ballast replaced and it went out within 20 minute, that's when he call me to help him, the Rexel electrical supply store a counter person told me that.new ballast is little different. But still work with one wire of blue.
It is 12 footer bulb and 70 watts 2 bulb in it!
Old 03-28-2012, 01:54 PM   #5
Rewards Points: 1,574
Make sure you are using new bulbs of correct type/size to match with the new ballast.
bob22 is offline   Reply With Quote
Replacing undercabinet halogen bulb with xenon bulb gabbie14 Electrical 10 09-26-2011 11:46 PM
Changed Ballast only 1 bulb works nbaresejr Electrical 6 06-24-2011 08:00 PM
Can I install a self-ballasted CFL bulb into a ballasted fixture? Daaavey Electrical 22 08-25-2010 09:52 PM
Circline bulb and ballast anton2148 Electrical 6 07-06-2010 04:16 PM
Metal halide lamp Richo Electrical 13 01-20-2008 03:37 PM
