Ballast - Electrical - DIY Chatroom Home Improvement Forum
Old 06-22-2012, 09:50 PM   #1
ballast
i have an old philips mark 3 r-2e75-s-3-tp 120v t12 that has black and white wire on one side and 1 red and 1 white wire on the other. I would like to change this out w/ a t8 ballast, what t8 ballast should I use? This is suppose to run 2 lights, can you also support in wiring diagram ? thank you -Scott phx
cdbob is offline   Reply With Quote
Old 06-22-2012, 10:57 PM   #2
Missouri Bound's Avatar
Isn't there a wiring diagram on the ballast? Ballasts are made for specific purposes.....what lamp does this ballast energize? No starter? It's a single lamp fixture I assume, correct?
Do you want it your way or the right way?
Old 06-22-2012, 11:17 PM   #3
" Euro " electrician
frenchelectrican's Avatar
It is not single lamp T12 verison at all due the OP provided the manufacter number and as soon I read the third number I knew this is a two lamp verison Those slimline have very oddball connection and they are only single leads to the tombstone however they must have current inturpeting tombstone this is a mantory item.
When go to T-8 verison of slimline it will still stay pretty much the same fashion ( I will have to double check the wiring diagram to confirm this due there is 4 differnt verison of conneciton on the slimline electrique verison )
Merci,
Marc
Old 06-25-2012, 04:06 PM   #4
Rewards Points: 266
Not so oddball if you are used to commercial/industrial fluorescent light installations. These are instant-start ballasts designed to fire the lamps once a day or fire them once and keep them on until something breaks. They are very efficient wrt power use and are inexpensive, but chew up the lamp electrodes if they are switched a lot.
cdbob, allow me to suggest that if you have a lot of these, plan on changing out most or all of them now. YOu will get a lot better deal on ballasts if you buy them in case quantity (on ebay). (You might save your old tubes to use in a couple of fixtures in which you retained the old ballasts.)
ionized is offline   Reply With Quote
Florescent ballast, commercial or residential? rjniles Electrical 183 05-13-2016 03:47 PM
Help replacing T12 Ballast hugocraft Electrical 36 12-21-2012 03:16 PM
New T5 Ballast causing Blinking gray0239 Electrical 3 01-04-2012 11:37 PM
T12 ballast to T8 c.bustle Electrical 5 07-10-2011 10:33 AM
No ballast in 48 inch fluorescent fixture. Timster Electrical 16 06-10-2010 04:02 AM
