Bais Board Heaters - Electrical - DIY Chatroom Home Improvement Forum
View Poll Results: how to instal bais board heaters
how to instal bais board heaters 0 0%
electric heaters 0 0%
Multiple Choice Poll. Voters: 0. This poll is closed
Old 07-30-2008, 02:48 PM   #1
Bais Board Heaters
I have really old house that use fuel for heat as u can se the fuel price
It is not worth to have that thing in the house any more
I am trying to install bias board heaters and the bias
Board heaters required 220w so how du I gat 220w from 110w
I will run new wires from panel and the panel is old 2 should I change panel 2
Or what please help before winter start thank you so much
Dado is offline   Reply With Quote
Old 07-30-2008, 03:56 PM   #2
Registered User
Termite's Avatar
If you have baseboard heaters that require 220 volts (not watts), you'll need to run new circuits to the panel to serve them. The wires that serve the 110 volt circuits in the house won't do the job.
Please don't take offense, but this isn't a DIY job for you. Based on the question, you probably need to hire an electrician to help you get this done, as proficiency with wiring and working in the electrical panel will definately be required. Whether or not the panel/service needs to be upgraded and updated is really a decision for an electrician to work out with you, because there's no way for us to assist with that question without seeing what you've got and what you're wanting to put in.
Old 07-30-2008, 07:49 PM   #3
Electrician's Helper
Pudge565's Avatar
Rewards Points: 150
Send a message via AIM to Pudge565
I second the call an electrician idea.
Pudge565 is offline   Reply With Quote
Tags
bais board heaters
Any experience with Dupont Real Touch elite laminate flooring? danidisney Flooring 12 08-24-2008 03:22 PM
Ridge board enough? runningforyou Roofing/Siding 9 08-13-2008 07:43 PM
Cracked ledger board on front porch King_Doodle Building & Construction 20 06-03-2008 09:16 PM
Installing deck ledger board over foam board? RickT Building & Construction 5 11-06-2006 10:50 PM
