A Bad Wire? - Electrical - DIY Chatroom Home Improvement Forum
Old 08-03-2011, 08:46 AM   #1
jzw
A bad wire?
All of a sudden, my kitchen lights and lights mounted on the outside of my house in the backyard stopped working. The breaker didn't trip. There's just no power. I wonder if it is because some wire comes lose behind the wall?
jzw is offline   Reply With Quote
Old 08-03-2011, 08:58 AM   #2
Rewards Points: 734
Are there any GFCI's on this circuit that may have tripped?
You could have a bad connection. The circuit breaker may have failed as well. Are you comfortable working in the panel? Can you measure the voltage between the breaker and neutral?
AandPDan is offline   Reply With Quote
The Following User Says Thank You to AandPDan For This Useful Post:
J. V. (08-03-2011)
Old 08-03-2011, 12:22 PM   #3
Rewards Points: 58
Dan is correct. Some dummy may have put these lights on a GFCI receptacle or breaker thinking it was required because its in a kitchen and outside. I bet it is GFCI related. I mean, I would actually bet money that's what it is.
The Following User Says Thank You to J. V. For This Useful Post:
AandPDan (08-03-2011)
Old 08-03-2011, 01:30 PM   #4
Licensed Pro
Wires generally won't come loose behind a wall. If it is a loose connection, it will be at a junction point, either at a light box or a switch box.
convert 3 wire range junction box to receptacle filby Electrical 0 06-05-2011 02:33 AM
HALP! Master/Remote Dimmer troubles! Confuserated Electrical 9 02-12-2010 04:30 PM
Burial wire and a seeming difference of opinion... SxS Electrical 19 02-24-2009 10:16 AM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 10:41 PM
Stranded wire on screw connections BigJimmy Electrical 7 01-19-2008 03:42 PM
