Bad Wall Switch For Ceiling Fan?? - Electrical - DIY Chatroom Home Improvement Forum
Old 05-16-2011, 10:34 AM   #1
bad wall switch for ceiling fan??
i have a 2 switch toggle style for ceiling fan with light kit in the sunroom (it works fine)and another with a larger toggle style switch with a slideing dimmer attatched for another ceiling fan with light kit( sorry I dont know the names of the different styles? My problem is with the switch with the slideing dimmer....the light kit works fine but the fan hums and will turn at about 1 rev/15 sec......the wall switch also hums(can hear it 5 ft away)...should i try and replace the switch with a basic 2 station switch or is the fan shot..I dont have a voltmeter...replacement fan is $75 min...its been this way since i moved in and the kitchen gets darn hot in the summer....sorry for the way i explained my problem....hope someone can help thx
doctordog is offline   Reply With Quote
Old 05-16-2011, 11:08 AM   #2
SD515's Avatar
Rewards Points: 504
I’d bet the dimmer isn’t rated for use with a fan. The lights yes, the fan no. (or the dimmer has gone bad)
You can test if the fan is still ok by removing the dimmer and wiring it direct or through a standard switch. Of course, shut the power off first before you open anything up.
The Following 2 Users Say Thank You to SD515 For This Useful Post:
doctordog (05-16-2011), Thurman (05-16-2011)
Old 05-17-2011, 12:09 AM   #3
" Euro " electrician
frenchelectrican's Avatar
I am with SD515 with simauir situation if you have the connection at the fan junction box wrong that what useally kill the dimmer and the dimmer is not used for celing fan motour at all.
I will use standard switch first to rule it out to make sure everything is functing correct once you sort it out then get proper dimmer or fan speed control or combo unit { with combo unit please pay attetion to the connections very carefull.}
I don't know if you mention us or not did you have a remote kit as well ?? if that the case please do not use the dimmer or fan speed control with the remote kit. { they can interfernce the operation and may case the damage to the remote unit }
The Following User Says Thank You to frenchelectrican For This Useful Post:
SD515 (05-17-2011)
Wiring an Intermatic Wall Timer in a three way switch aitutaki98 Electrical 6 07-23-2011 11:43 AM
Two Switches, an outdoor light, and a wall plug MichaelT Electrical 1 03-06-2011 05:17 PM
Help with four way switch jwetsit Electrical 3 05-04-2010 06:05 AM
Electrical outlet controlled by a wall switch? rinlo Electrical 14 12-28-2008 10:30 PM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 04:08 PM
