Bad Problem ! Very Very Very Very Bad! - Electrical - DIY Chatroom Home Improvement Forum
Old 03-07-2011, 01:09 PM   #1
joed's Avatar
Rewards Points: 11,990
I would say that is very wierd. Perhaps you should call an electrician to check it out.
Old 03-07-2011, 01:28 PM   #2
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 68
sounds like they ran the feeders to that breaker, somehow. If you are not comfortable troubleshooting something like this, I'd get a licensed electrician to check it out. Sounds like a potential dangerous situation depending on what is actually going on there.
Another possibility is that it's a sub panel, can you confirm that? It could be a sub and they just decided to feed it through a breaker instead of the main. Not sure if that is to code though and I see very little reason why to do it.
Red Squirrel is online now   Reply With Quote
Old 03-07-2011, 01:37 PM   #3
Rewards Points: 1,442
Could this be a new incomplete installation where an old service of perhaps 30 amps was back fed into one of the side breakers while awaiting a new service to be hooked up from the utility pole and connect to a new meter and then to the main breaker in that panel?
It was not unusual for old panels (with as little as two 15 amp fuses) to be mounted on the ceiling.
How old is the house?
How many breakers does the panel have?
2 TVs fried: Electrical vs. Comcast Coax Cable Problem LynOprinka Electrical 17 07-16-2012 09:01 PM
Very Strange Shower Drain Problem MattWhite Plumbing 12 05-21-2011 12:53 PM
Don't understand this breaker tripping problem majesticjess Electrical 10 03-05-2010 07:42 PM
Stymied by window leakage problem. Matth3w General DIY Discussions 5 06-11-2008 07:26 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 02:51 PM
