Old 11-15-2012, 12:24 PM   #1
bad outlet --doesn't trip breaker
I have an outlet that went out this morning..but did not trip the breaker. Turning breaker on/off does nothing. Plan to replace outlet..however we do not have grounds going to each outlet in this house. so when I reinstall new outlet what is proper procedure for ground wire in outlet ?
lynnralphie is offline   Reply With Quote
Old 11-15-2012, 01:19 PM   #2
If no ground wire is present, you need to replace the outlet with a GFCI or an ungrounded model.
sgip2000 is offline   Reply With Quote
Old 11-15-2012, 01:19 PM   #3
A "Handy Husband"
rjniles's Avatar
If you have no ground you have 1 of these options
Use a 2 wire receptacle
Install a GFCI receptacle (marked "NO GRD")
Install a GFCI breaker and a 3 wire receptacle(marked "NO GRD")
Coastal South Carolina
rjniles is offline   Reply With Quote
Testing outlet on AFCI breaker barley Electrical 11 10-24-2011 12:21 PM
Circuit Breaker trips when I plug into an outlet Alex in Orlando Electrical 3 09-05-2010 02:04 AM
Drilled through 12/3 and breaker didn't trip vseven Electrical 12 04-11-2010 12:03 PM
Just for fun Andy in ATL Electrical 56 10-20-2009 10:33 AM
Replaced Outlet, but now tripping the circuit breaker bman598 Electrical 9 05-21-2009 08:35 PM
