-   -   bad outlet --doesn't trip breaker (http://www.diychatroom.com/f18/bad-outlet-doesnt-trip-breaker-163422/)
lynnralphie 11-15-2012 11:24 AM
I have an outlet that went out this morning..but did not trip the breaker. Turning breaker on/off does nothing. Plan to replace outlet..however we do not have grounds going to each outlet in this house. so when I reinstall new outlet what is proper procedure for ground wire in outlet ?
sgip2000 11-15-2012 12:19 PM
If no ground wire is present, you need to replace the outlet with a GFCI or an ungrounded model.
rjniles 11-15-2012 12:19 PM
If you have no ground you have 1 of these options
Use a 2 wire receptacle
Install a GFCI receptacle (marked "NO GRD")
Install a GFCI breaker and a 3 wire receptacle(marked "NO GRD")
