Old 11-21-2008, 12:23 PM   #16
bad luck, bad lightbulbs, or bad problem?
Do they blow all over the house? Or just one area? Do they seem brighter? Turn on a furnace or dryer, do the lights get brighter?
rgsgww is offline   Reply With Quote
Old 11-21-2008, 02:05 PM   #17
It was a dark and stormy
Yoyizit's Avatar
Originally Posted by KE2KB View Post
Why would being close to the pole transformer cause light bulbs to burn out prematurely?
Higher voltage.
126v on a 120v bulb will give a life of 100(120/126)^12 = 56% of rated life.
In MD, PoCo is allowed to go between 114v and 126v. My xformer is right outside and I get 122v, +/-.
Old 11-22-2008, 11:21 AM   #18
Maybe installing CCFL replacement bulbs will work. They may not be as sensitive to higher voltage.
KE2KB is offline   Reply With Quote
Problem with fan coil unit/hydronic system. flood1911 HVAC 2 09-05-2008 05:57 PM
2 switches , one light problem pepperthecat Electrical 2 07-08-2008 04:57 PM
Stymied by window leakage problem. Matth3w General Discussion 5 06-11-2008 07:26 PM
Door -Storm Door problem bassman Building & Construction 2 01-17-2007 04:16 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 02:51 PM
