Bad Luck, Bad Lightbulbs, Or Bad Problem? - Electrical - DIY Chatroom Home Improvement Forum
Old 11-20-2008, 05:59 PM   #1
bjs
bad luck, bad lightbulbs, or bad problem?
We seem to be replacing light bulbs rather frequently. Is this just bad luck, or should we be exploring other causes?
bjs is offline   Reply With Quote
Old 11-20-2008, 06:05 PM   #2
Rewards Points: 5,336
Try to be a little more specific. Same fixture? All fixtures? Type of bulb? Off brand bulb? What's frequently?
Ron
Old 11-20-2008, 06:21 PM   #3
People stomping around on the floor above?
Your house being close to the pole transformer?
Old 11-20-2008, 06:42 PM   #4
the Musigician
DangerMouse's Avatar
i'm afraid you may have angered the light bulb fairy. she's siccing gremlins on you.
DM
Old 11-20-2008, 07:22 PM   #5
Rewards Points: 820
If you're talking about those 40 or 60W candelebra base that fit some vanity lights, they do burn out much more frequently than normal bulbs. Their small size usually means a hotter bulb.
I am thinking of replacing my fixtures with fluorescents.
Check your line voltage. If it's higher than 120, the bulbs probably won't last as long.
FW
Ultrarunner2017 is offline   Reply With Quote
Old 11-20-2008, 09:05 PM   #6
I think some big companies are greedy and intentionally are making them not last so long so they can make more money. Buy a different brand or get LED bulbs which should never burn out and also save electricity.
LED light bulbs (google)...
http://www.google.com/search?hl=en&q...s+cart&aq=f&oq=
Billy_Bob is offline   Reply With Quote
Old 11-20-2008, 09:56 PM   #7
Rewards Points: 820
Why would being close to the pole transformer cause light bulbs to burn out prematurely?
The only thing I can think of would be that close to the transformer, the voltage is highest, since POCO probably considers line drop over the greatest distance from the transformer, and being closer would result in a lower IR drop for you.
Old 11-21-2008, 06:28 AM   #8
chatterbass's Avatar
I had this problem with br30's from Home Depot. I would buy them a case at a time and would always be replacing them. So what I did was called the manufacturer of the bulbs and they sent me a refund for the lights. All I had to do was put all of the old light bulbs in the box they came in and send it to them. They even paid for the shipping. Needless to say I do not buy that brand of light bulbs from there anymore.
P.S.
when I switched the brand they last alot longer.
Good luck
chatterbass is offline   Reply With Quote
Old 11-21-2008, 08:26 AM   #9
Rewards Points: 150
First you have to understand the theory and history of light bulbs!
Here is a good link. http://www.btinternet.com/~homepage/dark.htm
Gary
Gary_602z is offline   Reply With Quote
Old 11-21-2008, 08:47 AM   #10
RippySkippy's Avatar
Oh no! I knew it was true. The old light bulb conspiracy theory is alive and well, glad to know there's others out here that agree with me!
when it comes to breakfast, the chicken is dedicated, the pig is committed.
LMASD
RippySkippy is offline   Reply With Quote
Old 11-21-2008, 09:01 AM   #11
the Musigician
you mean big companies are greedy and intentionally are making them not last so long so they can make more money? really???? ya THINK???
roflmao
DM
Old 11-21-2008, 09:09 AM   #12
Loose service neutral? Loose neutral on a MWBC? (Common theme being a loose neutral...)
I'm no expert--I'm far, far, far from it--but I'm a smart guy, and the theory that a loose neutral could cause over-voltage makes 100% sense, so check this angle out. (Maybe take a meter and do some voltage checks on your circuits, especially the sockets that are blowing bulbs...)
thegonagle is offline   Reply With Quote
Old 11-21-2008, 09:32 AM   #13
the Musigician
GOOD POINT! i thought someone had already said that, but the only one close was KE2KB!--> "Check your line voltage. If it's higher than 120, the bulbs probably won't last as long." i guess to US, the next step should be obvious, but thanks for bringing it up as we have no idea if the OP knew! good one.
DM
Old 11-21-2008, 11:11 AM   #14
Rewards Points: 820
That's a good point. Good thinking!
If the load on one leg is a lot higher (lower resistance) than that on the other, the bulbs on the leg with higher resistance would see higher than 110 if the neutral were to come loose.
If it's an intermittent problem, should show up as lights flickering brighter and dimmer.
Old 11-21-2008, 12:14 PM   #15
DIYer
If a lot of the bulbs were changed at once (maybe to put in a different spectral tone) then they will fail around the same time.
Also, if you leave them burning all the time, incandescents fail in about 4 weeks. 1000 hours isn't all that long.
Gigs is offline   Reply With Quote
Problem with fan coil unit/hydronic system. flood1911 HVAC 2 09-05-2008 05:57 PM
2 switches , one light problem pepperthecat Electrical 2 07-08-2008 04:57 PM
Stymied by window leakage problem. Matth3w General DIY Discussions 5 06-11-2008 07:26 PM
Door -Storm Door problem bassman Building & Construction 2 01-17-2007 04:16 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 02:51 PM
