-   -   bad luck, bad lightbulbs, or bad problem? (http://www.diychatroom.com/f18/bad-luck-bad-lightbulbs-bad-problem-32284/)
bjs 11-20-2008 05:59 PM
We seem to be replacing light bulbs rather frequently. Is this just bad luck, or should we be exploring other causes?
:eek:
Ron6519 11-20-2008 06:05 PM
Try to be a little more specific. Same fixture? All fixtures? Type of bulb? Off brand bulb? What's frequently?
Ron
Yoyizit 11-20-2008 06:21 PM
People stomping around on the floor above?
Your house being close to the pole transformer?
DangerMouse 11-20-2008 06:42 PM
i'm afraid you may have angered the light bulb fairy. she's siccing gremlins on you.
DM
Ultrarunner2017 11-20-2008 07:22 PM
If you're talking about those 40 or 60W candelebra base that fit some vanity lights, they do burn out much more frequently than normal bulbs. Their small size usually means a hotter bulb.
I am thinking of replacing my fixtures with fluorescents.
Check your line voltage. If it's higher than 120, the bulbs probably won't last as long.
FW
Billy_Bob 11-20-2008 09:05 PM
I think some big companies are greedy and intentionally are making them not last so long so they can make more money. Buy a different brand or get LED bulbs which should never burn out and also save electricity.
LED light bulbs (google)...
http://www.google.com/search?hl=en&q...s+cart&aq=f&oq=
Ultrarunner2017 11-20-2008 09:56 PM
Why would being close to the pole transformer cause light bulbs to burn out prematurely?
The only thing I can think of would be that close to the transformer, the voltage is highest, since POCO probably considers line drop over the greatest distance from the transformer, and being closer would result in a lower IR drop for you.
chatterbass 11-21-2008 06:28 AM
I had this problem with br30's from Home Depot. I would buy them a case at a time and would always be replacing them. So what I did was called the manufacturer of the bulbs and they sent me a refund for the lights. All I had to do was put all of the old light bulbs in the box they came in and send it to them. They even paid for the shipping. Needless to say I do not buy that brand of light bulbs from there anymore.
P.S.
when I switched the brand they last alot longer.
Good luck
Gary_602z 11-21-2008 08:26 AM
First you have to understand the theory and history of light bulbs!
Here is a good link. http://www.btinternet.com/~homepage/dark.htm
Gary
RippySkippy 11-21-2008 08:47 AM
Oh no! I knew it was true. The old light bulb conspiracy theory is alive and well, glad to know there's others out here that agree with me!
DangerMouse 11-21-2008 09:01 AM
you mean big companies are greedy and intentionally are making them not last so long so they can make more money? really???? ya THINK???
roflmao
DM
thegonagle 11-21-2008 09:09 AM
Loose service neutral? Loose neutral on a MWBC? (Common theme being a loose neutral...)
I'm no expert--I'm far, far, far from it--but I'm a smart guy, and the theory that a loose neutral could cause over-voltage makes 100% sense, so check this angle out. (Maybe take a meter and do some voltage checks on your circuits, especially the sockets that are blowing bulbs...)
DangerMouse 11-21-2008 09:32 AM
GOOD POINT! i thought someone had already said that, but the only one close was KE2KB!--> "Check your line voltage. If it's higher than 120, the bulbs probably won't last as long." i guess to US, the next step should be obvious, but thanks for bringing it up as we have no idea if the OP knew! good one.
DM
Ultrarunner2017 11-21-2008 11:11 AM
That's a good point. Good thinking!
If the load on one leg is a lot higher (lower resistance) than that on the other, the bulbs on the leg with higher resistance would see higher than 110 if the neutral were to come loose.
If it's an intermittent problem, should show up as lights flickering brighter and dimmer.
Gigs 11-21-2008 12:14 PM
If a lot of the bulbs were changed at once (maybe to put in a different spectral tone) then they will fail around the same time.
Also, if you leave them burning all the time, incandescents fail in about 4 weeks. 1000 hours isn't all that long.
