Bad Garage Door Install - Electrical - DIY Chatroom Home Improvement Forum
Old 03-09-2011, 04:30 PM   #1
Rewards Points: 1,522
Bad garage door install
Check this out:
http://www.break.com/cue-the-cuervo/...n-ever-2020629
bob22 is offline   Reply With Quote
Old 03-09-2011, 05:21 PM   #2
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,034
The real problem is that people who do things like this are allowed to breed and teach their kids these skills.
Coastal South Carolina
Old 03-09-2011, 05:22 PM   #3
Experienced
Jackofall1's Avatar
Whats wrong with that, everything is up to code isn't it? At least it would be in some parts of the world
Mark
Old 03-09-2011, 05:52 PM   #4
Learning Things Every Day
Jay 78's Avatar
Should have used a beefier extension cord...
Under Construction
Jay 78 is offline   Reply With Quote
Old 03-09-2011, 06:00 PM   #5
Rewards Points: 83
WOW! Sorta makes you sick to your stomach to know that people actually do stuff like that.
davido30093 is offline   Reply With Quote
Old 03-09-2011, 06:21 PM   #6
Experienced
Jackofall1's Avatar
That kinda reminds me of a project I did down in Mexico, there, it is very common to have (1) wire extension cords, yes you read that right, they will plug in, ground the neutral to building steel and run a single conductor to the area they need it, they have a pig tail on the power tool clamp neutral to building steel and plug into the (1) wire extension cord.
This also done with 550 Volt, with more wire of course, you never want to touch building steel and ground at the same time on a construction site in Mexico.
No matter how many time you cut up cords like this, how many time you take away the pig tails, they just keep on doing it, its amazing.
Mark
Old 03-09-2011, 08:01 PM   #7
Bigplanz's Avatar
Rewards Points: 914
That was pretty bad. This was deadly. Click on the 3-D animation of the installation.
http://isaacslaw.org/media.htm#
Bigplanz is offline   Reply With Quote
Weatherproofing garage help Perfik Building & Construction 2 10-17-2012 04:30 PM
The 12-Gauge Garage Jack Olsen Project Showcase 28 07-08-2012 11:21 PM
Raising up my garage jimmyfloyd Building & Construction 5 09-17-2009 11:39 PM
Garage Wiring issues jimmyfloyd Electrical 20 06-08-2009 03:57 PM
new double garage murray1426 Building & Construction 4 05-23-2009 02:11 PM
