Bad Electrical Outlet Now Nada - Electrical - DIY Chatroom Home Improvement Forum
Old 04-21-2013, 12:45 PM   #1
bad electrical outlet now nada
Ok so yesterday an outlet in my hall way I noticed a burning smell pops the cover off&saw one of the screws was cherry red.I then killed the main power&put in a new outlet.Used my tester to make sure it was wired correctly,said it was so I cut the power back on ran for 2 minutes then kicked off.I went&checked the breaker it seems fine clicks on & off as it should.My question before we start tearing up the walls is there a way the breaker could fail without thru normal non click of it?My buddy is an electrician he's on a job up north for a few days but when he he's back he said he will take care of it.But just looking for ideas.I'm guessing a short in the wire somewhere.
munstersdad is offline   Reply With Quote
Old 04-21-2013, 12:53 PM   #2
Rewards Points: 2,516
What in the world does this quote mean?
In the spirit of cooperation, have you checked for loose connections at this receptacle?
hammerlane is offline   Reply With Quote
Old 04-21-2013, 01:04 PM   #3
ha!Sorry I'm on via my phone&the kiddos are jumping allover me.I meant is there a way for the breaker to go bad but still click from the on to off position as if it was normal?Yes I've tightened everything up as best as possible.
Old 04-21-2013, 01:38 PM   #4
Oso954's Avatar
Rewards Points: 1,116
What tester is telling you it is wired correctly when the power is off ?
Oso954 is offline   Reply With Quote
Old 04-21-2013, 01:55 PM   #5
I apologize I worded that wrong.After I cut the power off I wired in a new socket&I turned it on&used one of those plug in testers that said it was correct then the power died,breaker didn't trip.I just went&pulled the breaker&tryd a new one same issue.
Old 04-21-2013, 02:15 PM   #6
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,214
Smart phones are the beginning of the end of civilized society
Coastal South Carolina
The Following User Says Thank You to rjniles For This Useful Post:
stickboy1375 (04-21-2013)
Old 04-21-2013, 06:10 PM   #7
I wired in a new socket&I turned it on&used one of those plug in testers that said it was correct .
Sockets are not a conductor of electricity. That is the problem.
Old 04-21-2013, 06:45 PM   #8
A "Handy Husband"
rjniles's Avatar
Not sure Hammer, seems that that socket will conduct pretty well
operagost (04-22-2013)
Old 04-21-2013, 06:54 PM   #9
" Euro " electrician
frenchelectrican's Avatar
Once you see one of the screw got red hot you will have to check more closer to the rest of the conductors ( wires ) to make sure there is no more damage. This part you will have to take a closer look toward back of junciton box to make sure there is no more heat damage inside that receptale loctaion.
What ya running on this circuit which do use a bit of power ?
If the breaker do kick out very fast more likey that you have a short circuit so as I mention above check the affected recpetales then check the others recepeticals for any more damage.
Merci,
Marc
Electrical outlet receptacle touching copper hydro pipe Jimmyswo Electrical 8 11-17-2012 10:27 AM
Schedule 40 PVC in Chicago? franwalker Electrical 56 12-20-2011 10:04 PM
Installing Electrical Outlet in the place of an old Light Fixture Mikon8er Electrical 20 11-08-2011 09:23 PM
Odd voltages at outlet TJF Electrical 12 11-01-2011 09:13 PM
HELP Installing Fault Interrupter Electrical Outlet!!!! pancho12 Electrical 5 06-15-2010 04:38 PM
