Bad Dimmer Switch? - Electrical - DIY Chatroom Home Improvement Forum
Old 08-07-2012, 11:27 AM   #1
Bad dimmer switch?
I swapped out some pendant lights over my bar. They were working fine for hours then a pop and a spark at the ceiling. Turns out that when the house was built some of the sheathing was removed and the bare wire hit some metal in the box causing it to arc. This has been fixed but the lights will not come on. Could the dimmer switch be bad now?
mlucas is offline   Reply With Quote
Old 08-07-2012, 12:29 PM   #2
Licensed electrician
Rewards Points: 1,266
This could be a tripped breaker or a blown fuse also.
Old 08-07-2012, 12:49 PM   #3
Rewards Points: 13,300
Or a GFI.
Old 08-07-2012, 02:01 PM   #4
There are no tripped breakers, blown fuses or GFI's to be reset.
Old 08-07-2012, 03:08 PM   #5
Electrical Contractor
jbfan's Avatar
Rewards Points: 252
Make sure the power is off and bypass the dimmer to see if it works.
Old 08-07-2012, 05:23 PM   #6
It very easily could be bad, the surge current could have destroyed the TRIAC before the breaker tripped.
freedomlives is offline   Reply With Quote
Old 08-07-2012, 08:12 PM   #7
Electrician Melbourne
Check if it has something to do with the pendant lights.
MEC Group is offline   Reply With Quote
Old 08-07-2012, 09:44 PM   #8
Pure Genius
Rewards Points: 150
My guess is bad dimmer switch. It doesnt take much to smoke them
Dierte is offline   Reply With Quote
Old 08-08-2012, 01:57 AM   #9
" Euro " electrician
frenchelectrican's Avatar
Very simple the dimmer is toasted when it was arc'ed out inside the junction box and the dimmer are famous for not taking a short circuit at all even some of the indentscent bulbs can knock the dimmer out of commison which I have see it from time to time.
So simple test is put a standard single or three way switch and test it to see the luminarie do come on without issue if that work fine then you know the dimmer is toasted some case you can smell it from the dimmer housing.
Merci,
Marc
Dimmer switch issues idlewatcher Electrical 0 03-07-2011 02:28 PM
Changing from dimmer to regular switch..help!!!!!!!!!!!!!!!!!!!!!!! Gomezy3k Electrical 8 10-04-2010 04:26 PM
Need help installing a dimmer switch { PICTURE } Brieninsac Electrical 8 11-20-2008 01:25 PM
Bathroom electronic dimmer gets reset by exhaust fan switch? BinaryJay Electrical 3 07-16-2008 11:57 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 02:19 AM
