-   -   Bad dimmer switch? (http://www.diychatroom.com/f18/bad-dimmer-switch-152917/)
mlucas 08-07-2012 11:27 AM
Bad dimmer switch?
I swapped out some pendant lights over my bar. They were working fine for hours then a pop and a spark at the ceiling. Turns out that when the house was built some of the sheathing was removed and the bare wire hit some metal in the box causing it to arc. This has been fixed but the lights will not come on. Could the dimmer switch be bad now?
Jim Port 08-07-2012 12:29 PM
This could be a tripped breaker or a blown fuse also.
joecaption 08-07-2012 12:49 PM
Or a GFI.
mlucas 08-07-2012 02:01 PM
There are no tripped breakers, blown fuses or GFI's to be reset.
jbfan 08-07-2012 03:08 PM
Make sure the power is off and bypass the dimmer to see if it works.
freedomlives 08-07-2012 05:23 PM
It very easily could be bad, the surge current could have destroyed the TRIAC before the breaker tripped.
MEC Group 08-07-2012 08:12 PM
Check if it has something to do with the pendant lights.
Dierte 08-07-2012 09:44 PM
My guess is bad dimmer switch. It doesnt take much to smoke them
frenchelectrican 08-08-2012 01:57 AM
Very simple the dimmer is toasted when it was arc'ed out inside the junction box and the dimmer are famous for not taking a short circuit at all even some of the indentscent bulbs can knock the dimmer out of commison which I have see it from time to time.
So simple test is put a standard single or three way switch and test it to see the luminarie do come on without issue if that work fine then you know the dimmer is toasted some case you can smell it from the dimmer housing.
Merci,
Marc
