Old 05-06-2011, 02:44 PM   #1
Bad Dimmer?
Funny thing happened the other evening. I Have had six new cans in the kitchen ceiling for a few weeks now. The other night one of the lights blew out, (the one with the hot wire loop out to the dimmer switch). After that, the switch was always on no matter what the actual position.
All the wiring looked fine at the light and the switch. Replaced the dimmer and all works well. Could a bulb burning out cause a dimmer switch to go bad like that?
I'm gonna hurl myself against the wall
because I'd rather feel bad than not feel anything at all
Warren Zevon
handifoot is offline   Reply With Quote
Old 05-06-2011, 03:10 PM   #2
I=E/R
a7ecorsair's Avatar
Bad Dimmer?
You may never know the full answer and whether it is the result of the bulb burning out or because of a voltage spike. Bad neutral connections at the service can cause weird problems.
a7ecorsair is offline   Reply With Quote
Old 05-06-2011, 07:28 PM   #3
Electrical Contractor
kbsparky's Avatar
Bad Dimmer?
Originally Posted by handifoot View Post
... Could a bulb burning out cause a dimmer switch to go bad ....
Yup. Happens all the time. If the filament blew out with explosive force, the 2 leads that hold up the filament could have shorted out, which can in turn trip a breaker, and/or burn out a dimmer.
I've seen halogens do the same thing.
-KB
Old 05-06-2011, 10:43 PM   #4
" Euro " electrician
frenchelectrican's Avatar
Bad Dimmer?
I have see them when the bulb burn out and blow the dimmer out when the filment arc'ed out.
Some dimmer can withstand couple blowout on bulbs but direct short circuit will always fried them out.
Merci,
Marc
frenchelectrican is online now   Reply With Quote
4 way dimmer jamiedolan Electrical 7 08-24-2010 01:45 AM
HALP! Master/Remote Dimmer troubles! Confuserated Electrical 9 02-12-2010 04:30 PM
Dimmer switches brokenknees Electrical 9 11-29-2009 06:59 PM
Basic Switch wiring question; Dimmer to Toggle switch (Pictures included) inspectator Electrical 8 08-07-2007 02:19 AM
When Bulb blows, Dimmer Switch Blows mAv19 Electrical 2 05-26-2006 04:52 PM
