-   -   Bad Dimmer? (http://www.diychatroom.com/f18/bad-dimmer-103760/)
handifoot 05-06-2011 01:44 PM
Bad Dimmer?
Funny thing happened the other evening. I Have had six new cans in the kitchen ceiling for a few weeks now. The other night one of the lights blew out, (the one with the hot wire loop out to the dimmer switch). After that, the switch was always on no matter what the actual position.
All the wiring looked fine at the light and the switch. Replaced the dimmer and all works well. Could a bulb burning out cause a dimmer switch to go bad like that?
a7ecorsair 05-06-2011 02:10 PM
You may never know the full answer and whether it is the result of the bulb burning out or because of a voltage spike. Bad neutral connections at the service can cause weird problems.
kbsparky 05-06-2011 06:28 PM
Originally Posted by handifoot (Post 643192)
... Could a bulb burning out cause a dimmer switch to go bad ....
Yup. Happens all the time. If the filament blew out with explosive force, the 2 leads that hold up the filament could have shorted out, which can in turn trip a breaker, and/or burn out a dimmer.
I've seen halogens do the same thing.
frenchelectrican 05-06-2011 09:43 PM
I have see them when the bulb burn out and blow the dimmer out when the filment arc'ed out.
Some dimmer can withstand couple blowout on bulbs but direct short circuit will always fried them out.
Merci,
Marc
