Bad Connection At Panel Box. - Electrical - DIY Chatroom Home Improvement Forum
Old 10-26-2007, 02:38 PM   #1
Bad connection at panel box.
I'll get right to the point. For some reason I was not getting power to the wall receptacles in my playroom, which has a dehumidifier clicking on and off normally to keep the place at a decent humidity. So I went straight to my 200 amp panel box. When I pulled the circuit breaker out I noticed it had a buildup of carbon or what ever, where it connects to the panel box bus. Also where, the male part of the bus slides into the circuit breaker, had a bunch of buildup on it to.
I then removed the buildup to on both sides of the bus insert with a foul and finished off with a diamond-based cloth which made things pretty clean. I then installed a new circuit breaker. I then finished off by blowing out the 200 amp Murray panel box with compressed air. My question now is did I do the right thing?
today is offline   Reply With Quote
Old 10-26-2007, 03:26 PM   #2
joed's Avatar
Rewards Points: 13,708
Normally a burnt bus connetion is not repairable depends on how bad it was. If it was me and I had some empty slots I would move the new breaker to the unused slots or I would consider a complete panel replacement.
Old 10-26-2007, 03:59 PM   #3
Electrician philosopher
This may sound like a silly question , but would you tell us the name brand, type, and approx. year of installation???
Andy in ATL is offline   Reply With Quote
Old 10-26-2007, 05:09 PM   #4
Licensed Pro
I bet it's an ITE, circa early 80's.
Old 10-26-2007, 06:08 PM   #5
Maybe a Zinsco. That was my gut..
Old 10-27-2007, 11:20 AM   #6
joerd,
Thank you for the info. I talked to a local electrician, and he said what I did was just fine.
Now I have to make up my own mind and decide which is best. Leave it alone? or move it.
Andy: 200 amp Murray, CTL. Installed in the late 70s.
Old 10-27-2007, 01:04 PM   #7
joed's Avatar
If you have the space in the panel it is very simple to move it. I would do it.
Old 10-27-2007, 01:26 PM   #8
Originally Posted by today View Post
joerd,
Once the metal buss bar has heated once, it is more likely to heat again. The metal becomes dammaged.
If you are lucky, you can move the breaker to a new spot in the panel. You may need to replace the entire panel guts, or entire panel.
I would watch this breaker for signs of heating.
Master Electrician
jwhite is offline   Reply With Quote
Old 10-27-2007, 11:22 PM   #9
The bus stabs (the part where it makes contact) on aluminum bussed panel is plated with a thin layer of tin. If you filed it away, it's not a matter of "if" it will go, but a matter of "when". The overheating doesn't make matters any better.
If you have space in the panel on the same phase as the burnt one, you need to put a NEW breaker in that space. If not, a panel change is necessary.
DuncanB is offline   Reply With Quote
This doesnt seem right. JoulesWinfield Electrical 27 07-26-2009 07:40 PM
Outdoor breaker panel questions lhoney2 Electrical 12 07-19-2007 05:44 PM
Splice in Neutral to Panel - OK or Not? allpraisebob Electrical 4 08-12-2006 05:54 AM
Adding new circuit breakers to 100 amp sub panel DrP Electrical 8 05-25-2006 10:05 PM
