Bad Circuit Breaker?? HELP!! - Electrical - DIY Chatroom Home Improvement Forum
Old 12-31-2006, 05:17 PM   #1
My oven is 240v
I have a double pole 40 amp breaker that keeps tripping
I've checked the oven wiring twice and nothing is touching, and everything looks good, but it keeps tripping
It just did it again, I went to the box to reset, and the breaker won't lock back 'on'
Do I need to replace it? I'm assuming yes!
TIA
davo420 is offline   Reply With Quote
Old 12-31-2006, 05:36 PM   #2
Is your stove hard wired in .If there is a plug you may want to unplug stove and see if breaker will reset and not trip.This will tell you if the problem is in the stove or electrical circuit.
trollmastergeneral is offline   Reply With Quote
Circuit breaker panel - Advice needed justtired Electrical 15 12-13-2007 06:55 AM
So lost - electrical requirements please help lapsis9 HVAC 4 12-20-2006 09:09 PM
Heat Pump compressor trips circuit breaker joejean HVAC 3 08-28-2006 01:15 PM
Replacing a circuit breaker PaulGray Electrical 3 05-13-2006 10:17 PM
Circuit breaker keep retripping Gregg Electrical 4 02-18-2006 06:11 AM
