Old 01-30-2013, 06:28 PM   #1
Bad Circuit Breaker????
Had power (volts/amps) to a circuit...receptacle, small wall heater and another receptacle (all 110vac). My grandson was pulling the plug out of the 1st receptacle....installed a "twist and snap closed" receptacle cover. He kept pulling the plug out but it snapped closed.
Lost power to all 3 (2 receptacles and heater). Same circuit where plug was being pulled out. Have replaced the 1st receptacle, all lug connections, no back wiring, still no power. Checked everything with voltage checker and wand...nothing. Checked all breakers (on/off test and tested with wand) not finding a bad breaker. Bought a Breaker Finder/Tester. Will that be reliable in finding a faulty breaker, if that's the case? Don't want to start pulling breakers out unless I'm fairly certain.
Any other thoughts or ideas?
Thanks,
Bob---PA
dolanbob is offline   Reply With Quote
Old 01-30-2013, 07:41 PM   #2
An old Tradesmen
Moved to Electrical forum.
Old 01-30-2013, 07:54 PM   #3
Licensed electrician
Check the connections at the last working or first non-working receptacle.
Speedy Petey (01-30-2013)
Old 01-30-2013, 10:01 PM   #4
Licensed Electrical Cont.
Speedy Petey's Avatar
There is NO way you can accurately troubleshoot with a want tester alone.
You say you checked all the breakers and they did show power with the wand anyway. What makes you thin it is a bad breaker?
For you and anyone else reading this in the future. 99% of the time the breaker is either good, or is good and doing it's job if tripping. It's most likely NOT a bad breaker.
Speedy Petey is online now   Reply With Quote
New wiring tripping breaker on another circuit? Kinggofg Electrical 11 04-26-2012 02:36 AM
Backfeed Circuit Breaker Knucklehead_BW Electrical 13 01-11-2012 10:17 PM
circuit breaker? blueandyellow Electrical 7 01-30-2011 11:27 PM
Circuit BReaker Question - breaker didn't trip and no power thru the circuit Ronin_67 Electrical 2 08-08-2008 07:06 AM
Circuit breaker panel - Advice needed justtired Electrical 15 12-13-2007 06:55 AM
