Bad Breaker? - Electrical - DIY Chatroom Home Improvement Forum
Old 10-25-2008, 09:25 AM   #1
the Musigician
DangerMouse's Avatar
bad breaker?
my bedroom light just went off.... hmmmm, i check breaker and it's tripped. reset it and in 8 seconds it trips again. hmmm, unplugged everything in the bedroom, ....same thing. bad breaker?
DM
Old 10-25-2008, 09:31 AM   #2
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,956
No, the breaker is doing it's job. You have a short circuit somewhere.
I know for a lay person a "bad breaker" is always a first thought knee-jerk reaction to a tripping breaker, but this is not the case 99.9% of the time.
Usually a breaker trips for a reason.
Old 10-25-2008, 09:48 AM   #3
the Musigician
wouldn't a short trip immediately? it varies from 4 to 10 seconds.... and i THINK we unplugged everything in the room. still checking.
DM
Old 10-25-2008, 10:10 AM   #4
the Musigician
found the culprit.... the previous owners evidentally patched into that line to run an outside pump that seems to have just died.... owell. at least i know what it is now. i disconnected it as it is not needed now and will rewire next year up to code when i tackle that end of the home. thanks speedy! end of thread.
DM
Old 10-25-2008, 10:14 AM   #5
Swap the cable to another breaker and find out.
Some heavy load (motor) devices have a built-in "surge protection" that stops an initial heavy draw. An example of this is a soft-start router. But there are many more. The only true test to see if you have a draw on the circuit is an ammeter. A VERY crude test is to disconnect the neutral and see if it arcs as you attach and remove it from the neutral bus. You can normally see an arc for 1 amp draw. Be careful though because the neutral wire is LIVE when it is disconnected and there is a device or short on it.
You can also test the voltage of the disconnected neutral. If there are no devices or shorts on it then it should register less than 3 volts. If it registers 110 plus then you haven't switched everything off or unplugged everything, or you have a short.
Edit: sorry - too late - replied between messages
Paulustrious is offline   Reply With Quote
Circuit breaker panel - Advice needed justtired Electrical 15 12-13-2007 05:55 AM
20 Amp Breaker tripping with GFCI panhandlion Electrical 7 12-12-2007 08:59 PM
Problem with circuit breaker. HELP! spartanic Electrical 2 10-28-2007 03:09 PM
Outdoor breaker panel questions lhoney2 Electrical 12 07-19-2007 05:44 PM
Breaker Buzz SkipI Electrical 2 07-13-2007 07:48 PM
