Backstabbing Questions
I see that most of you folks in the know consistently advise against "backstabbing" when connecting outlets. As always, I'm deferring to the experts out there and not backstabbing, but I do have a couple questions:
1) Why is backstabbing a poor practice? 2) If it's such a bad practice, why are outlets manufactured with backstabbing as an option? I know it's much easier and quicker to backstab (especially for us diy'ers), but if it dangerous, I'd think that the manufacturers would eliminate the backstabbing option. Any input would be appreciated. Thanks in advance. |
Good question. While I do not back stab, many contractors do because it saves time. Most if not all devices with back stab capability are 15 amp. Like recepts and switches. Thus not allowing for #12 wire to be used.
Back stab devices do not afford as good a connection as the wrap screw method. Only a blade with little surface area is compressed in the stab. When wrapping a screw your surface area is much larger and a much more secure connection results. If the screw is not used properly that also can relate to a bad connection. There is nothing wrong with back stab. But I have found that I personally like to use the screw, especially if you need to remove the device. |
I paid a little extra and bought backwired outlets for my basement. The backwiring isn't the same as the springloaded stab in connection. This is a compression connection that tightens with the same side screw on the outlet.
The problem is, these only rely on the spring to make the connection. Over time, the spring looses it's tension, especially with heavy loads on the device. About 80% of all service calls I've done where a receptacle isn't working, it was due to the stab connection. Avoid this practice, even if it is legal. InPhase277 |
Originally backstabbing outlets allowed for 14g and 12g copper wire, now 12g is no longer allowed. 14g is allowed but many in the field do not like the way they make the connection and would not use them. Easy is not necessarily better. It is not dangerous, just not preferred or long lasting. For the same reason there are 49c receptacles and also $2, 3 & 4 receptacles for the same 120v, 15a duplex outlet. You will likely get the quality you pay for. I prefer the backwired outlets since you can tighten the screw to increase pressure. Backstabbing has no provision to do this. |
Can I backwire a 20 amp GFCI?
Thanks for your responses. They are greatly appreciated. Another question: The outlets I bought are 20 amp for use on the kitchen counter. The first in the chain of three is a GFCI. The others are not. They are connected with 12g wire. The outlets allow for backwiring NOT backstabbing - not knowing there was a difference, I used the wrong term in the original post. Thanks to all of you who set me straight regarding the difference between the two terms. Given the use of 12g wire, can I backwire these 20 amp outlets? I hope so because it will save a ton of time, but if you folks say no, that's good enough for me. Thanks again for your help.
Yes, backWIRING can be done with 12AWG.
BTW, I have a question. The newer push in wire connectors... are they the same principal as backstabbing? |
InPhase277 |
InPhase277 |
-David |
| All times are GMT -4. The time now is 06:45 PM. |
