Backsplash - Electrical - DIY Chatroom Home Improvement Forum
Old 03-01-2010, 03:04 PM   #1
Question
Backsplash
My kitchen back slpash has way too many AC outlets. I want to install a tile backsplash and need to bypass and outlet or two.
The wiring is now romex. Could I just remove the outlet (one or two) and wire nut the splice then shrink tube over the connection then cover plat the outlet. Then install the tile backsplash?
Tobor
tobor is offline   Reply With Quote
Old 03-01-2010, 03:16 PM   #2
All splices need to remain in an accessible box with a cover
So you will either have a blank cover plate or an outlet
Makes no sense to me to remove an outlet only to put a blank face plate on ?
Outlets are needed every 4' in the kitchen, plus serving every counter
Plus Min (2) 20a circuits required
Old 03-01-2010, 04:30 PM   #3
Thanks for your reply and schematic Dave, lots of help.
Tobor
Old 03-01-2010, 06:06 PM   #4
Electrician
Rewards Points: 760
I think you are the first person complaining about to many outlets in the kitchen, most people complain there is not enough.
darren is offline   Reply With Quote
Old 03-02-2010, 04:12 PM   #5
I do
LOL, Given my kitchen layout and the spacing of the outlets I could eliminate two of then. I found this out after seeing Dave's drawing and thaking with the county about what I now have.
The problem is the space I want to install the backsplash is small a 4ft section then there is a stove another 4ft section and a 3 ft 90.
Each section has two outlets. So I wanted to remove the outlet wirenut the connections shrink tubing them and closing the open off and tile over it.
I'm I correct in understanding you can't cover over a connection like that?
Old 03-02-2010, 04:19 PM   #6
Licensed electrician
Rewards Points: 996
That is correct, all junctions must remain permanently accessible.
Tiling / backsplash question Mark755 Kitchen & Bath Remodeling 4 02-26-2010 02:01 PM
Backsplash behind all counters? Birdsell5 Remodeling 2 12-19-2009 07:16 AM
backsplash... change of plans juliebun Kitchen & Bath Remodeling 2 06-07-2009 05:27 PM
Can I put up a glass-block backsplash over a laminate? coreyjan Tiling, ceramics, marble 1 05-24-2009 08:47 AM
Attaching a backsplash to wall/countertop DanBress Carpentry 3 09-10-2008 09:09 PM
