Backless Handy Boxes - Electrical - DIY Chatroom Home Improvement Forum
Old 05-20-2012, 04:38 PM   #1
Rewards Points: 512
Are 1-1/2" DEEP backless Handy boxes made for box extensions? All I can find at the Orange Stores are 1-7/8" and that is too deep for what I need (this box sticks out of finished wall too much - 3/8" too much), and the box inside the wall is too far back and can't be pulled forward enough to be flush.
If not available, what do you recommend?
Old 05-20-2012, 04:46 PM   #2
They are made. Crouse-Hinds has one, part number TP592.
http://www.mrsupply.com/cooper-crous...ngs-tp592.html
LooseSCruz is offline   Reply With Quote
The Following User Says Thank You to LooseSCruz For This Useful Post:
sirsparksalot (05-20-2012)
Old 05-20-2012, 04:50 PM   #3
Rewards Points: 512
thew box in the wall is for a 1 gang duplex receptacle
Old 05-20-2012, 04:51 PM   #4
Code05's Avatar
Rewards Points: 1,104
http://www.aifittings.com/products/spec-sheets/be1.pdf
Adjustable.
Code05 is offline   Reply With Quote
The Following 2 Users Say Thank You to Code05 For This Useful Post:
k_buz (05-20-2012), sirsparksalot (05-20-2012)
Old 05-20-2012, 07:12 PM   #5
Rewards Points: 512
thank you, thank you
Old 05-20-2012, 07:48 PM   #6
Don't forget your box fill calc.
The Following User Says Thank You to Yoyizit For This Useful Post:
Boxes recessed too deep rondo Electrical 10 12-01-2012 06:46 PM
Grounding Questions - Boxes, Devices, Taps, Terminations aaronk Electrical 11 12-17-2011 09:13 PM
Can I cover unwanted electrical boxes (ie switch box) with drywall?? DanDaMan Electrical 15 03-07-2011 02:59 AM
Building Planter Boxes kimberland30 Landscaping & Lawn Care 1 05-15-2009 10:19 PM
wiring outlet boxes, steel or plastic? DangerMouse Electrical 17 07-20-2008 12:05 PM
