Backfeeding With A Portable Generator - Electrical - DIY Chatroom Home Improvement Forum
Old 09-28-2011, 11:22 AM   #1
Just call me Andrew
Rewards Points: 1,020
Backfeeding with a portable generator
A friend of mine has routine power outages and would like to get his generator fed into the panel...I plan to help.
Is it as simple as putting an inlet receptacle of the proper rating on the outside of the house, feeding that receptacle to the appropriate breaker size and location on the main panel, and installing an interlock kit?
Can you backfeed into the main panel (and he would have to be cautious of which items or breakers he turns on during an outage) or must it be to a subpanel?
Thanks.
Andrew
secutanudu is offline   Reply With Quote
Old 09-28-2011, 11:26 AM   #2
Rewards Points: 160
It must be the main panel. Otherwise you would need two (2) interlock kits. And how would the second kit be safely used each time the generator is used? So feed the main panel only. Then he can feed the sub with generator power.
I like to suggest an ATS for this application.
Old 09-28-2011, 11:35 AM   #3
Just call me Andrew
Does there have to be a subpanel at all? Or can he just feed his main panel with the generator, and turn off non-critical breakers.
Andrew
Old 09-28-2011, 12:04 PM   #4
Licensed electrician
Rewards Points: 1,610
Andy, were you asking about a generator fed subpanel or a subpanel utility fed off of the main panel?
Old 09-28-2011, 12:15 PM   #5
Just call me Andrew
I was asking about a generator-fed panel....but was hoping to just do it without having to add a sub.
Andrew
Old 09-28-2011, 12:20 PM   #6
Just put the interlock on the main panel.
Old 09-28-2011, 12:21 PM   #7
No. A sub panel is not required. Post the make and model of the main panel in question and I can suggest an appropriate interlock.
Auger01 is offline   Reply With Quote
Old 09-28-2011, 01:05 PM   #8
Just call me Andrew
It's a 200A square-d - i forget homeline or QO, but I know it's the cheaper of the two.
I assume this is the one (the first one on the list):
http://www.interlockkit.com/squareDmain01.htm
Andrew
Old 09-28-2011, 01:21 PM   #9
Homeline has the 1" breakers and is the less expensive line.
Old 09-28-2011, 02:13 PM   #10
Just call me Andrew
yup, that's the one.
Is that website the only place to get them? Guess I can check a local supply house.
Andrew
Old 09-28-2011, 02:15 PM   #11
Any supply house for Square D should be able to get the parts you need.
Old 09-28-2011, 02:17 PM   #12
Just call me Andrew
I believe it's an 8000 watt generator. Safe to backfeed that with a 60A breaker? (3) #6 and (1) #10 EGC?
I just hook up the iutlet like I would any 240v outlet, right? 4 wires between the panel and the inlet?
Andrew
Old 09-28-2011, 04:27 PM   #13
For an indoor panel use part number HOMCGK2. For an outdoor panel the part number is HOMRBGK2. They list for about 60 to 70 bucks.
Here is a link to square D interlock info:
http://members.rennlist.org/warren/SQDinterlockkit.pdf
An 8000 watt generator only puts out a maximum of 33 amps at 240 volts. I would go with a 30 amp breaker and 10 ga. wire to a L14-30 inlet. If he plans on a bigger genny later, by all means put the bigger stuff in now.
If its a vintage panel, there is a aftermaket kit that would work from interlockkit.com, but they cost around 150.00.
Powering boiler with portable generator piacentini Electrical 14 01-06-2011 09:01 AM
wiring portable generator into two house panels Rage Electrical 7 12-21-2010 04:40 PM
Portable generator and Lennox furnace joshbloomberg Electrical 7 02-10-2010 10:25 PM
portable generator questions--long post daddyrabbit Electrical 19 01-27-2010 07:40 PM
Better way to protect portable generator inlet? IvoryRing Electrical 7 05-30-2006 07:30 PM
