Backfeed Through RV Circuit? - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Old 07-31-2012, 09:55 PM   #31
Rewards Points: 1,452
The generator feed circuit is sized for however large a generator you or someone else might put behind the house. For example a 50 amp generator would require #6 wires from the inlet to the panel (and a 50 amp breaker set in the panel for back feeding.)
The house branch circuit to supply power to the RV is sized for the amount of current the RV can draw from the house supply. The RV may have an attached cord and a plug whose shape specifies the amperes such as 20 or 30 or 50. Install a matching receptacle on the side of the house and string appropriate wires to the panel for example #10 wires for 30 amps.
AllanJ is online now   Reply With Quote
Old 07-31-2012, 11:03 PM   #32
dmxtothemax's Avatar
Rewards Points: 5,108
Originally Posted by stickboy1375 View Post
What is a change over switch?
It is a large DPDT switch !
Wired to the main panel,
so the main supply can be sourced from either the grid or genny,
But never from both.
In Australia they dont use mechanical interlocks,
It must by code be a proper change over switch.
Many people still use back feed cords thou !
dmxtothemax is offline   Reply With Quote
Old 08-01-2012, 06:08 AM   #33
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
I know what a transfer switch is, I just never heard the term change over switch used before.
Old 08-01-2012, 08:06 AM   #34
DIY staff
Rewards Points: 7,174
Is this RV inside a garage? Sounds like a carbon monoxide problem---just sticking my nose in where it doesn't belong---Mike----
Old 08-01-2012, 11:17 AM   #35
Ntwrk. Systems Engineer
Nope, sits on an asphalt pad along side of the garage. The 5th Wheel is 40' long and 13' high. Wish I had a garage that big!
5th_Time is offline   Reply With Quote
Old 08-03-2012, 12:06 AM   #36
That is an entirely different thread and I bet mike would be on it.
Evstarr is offline   Reply With Quote
Tags
50a , generator , trailer
New circuit breaker owen22 Electrical 14 01-12-2010 08:08 PM
open circuit unknown location / voltage leakage fishmanflats Electrical 4 12-23-2009 10:04 PM
Changing a 3 way circuit...using recessed lighting box as a junction box? Oxymoron Electrical 1 12-07-2009 07:46 PM
Circuit out but circuit breaker didn't trip PaulenAndrew Electrical 17 08-16-2008 09:38 AM
