Backfed Main Breaker Space - What Would I Do With It? - Electrical - DIY Chatroom Home Improvement Forum
Old 06-07-2011, 06:18 PM   #1
Rewards Points: 1,016
Backfed Main Breaker Space - what would I do with it?
This is a subpanel in my workshop - has a space noted for a backfed main breaker. How would this be utilized?
The sticker is located just below the empty space in the lower left of the panel.
Backfed Main Breaker Space - what would I do with it?-photo-1-copy.jpg   Backfed Main Breaker Space - what would I do with it?-photo-2-copy.jpg
Old 06-07-2011, 06:23 PM   #2
Sparky
Rewards Points: 510
it appears the breaker bottom right is a 100A 2 pole, ... that should be your 'main breaker' just installed on the wrong side works on the same principal, but it looks like the left side has the hold down kit.
Techy is offline   Reply With Quote
Old 06-07-2011, 11:40 PM   #3
Yes, bottom right is 100a 2 pole main breaker acting as the disconnect. As for being installed on the wrong side, that's the way it came installed out of the box if I recall correctly.
When you say works on the same principle, that's what I was wondering - why would the lower left be called out specifically as backfed space?
Another picture -
Old 06-08-2011, 05:54 AM   #4
Sparky
Rewards Points: 510
a plug on backfed main breaker requires a 'hold down kit', it looks like there is a 'hold down kit' installed in the position it calls out
Old 06-08-2011, 08:05 AM   #5
Electrician
SD515's Avatar
Rewards Points: 504
Is that a hold-down kit on the right side, and is currently holding the 100A-2 pole?
It’s hard to tell from the pic’s, but a difference I might be seeing is it looks like the left side might be bonded to the tub, and the right side might not be.
Kyle
Old 06-08-2011, 09:28 AM   #6
Mad Scientist
See that L-shaped metal bracket sticking out to the left of the current main breaker? It looks like if the breaker were in the left position instead, that bracket would engage the notch in the end of the breaker to hold it down.
That breaker should be moved to the designated position, and it looks like you have slack in the wire to do so. The reason code requires some means of holding down a backfed main breaker is so that there won't be a breaker with energized bus clips flopping around if it is accidentally or intentionally removed from the bus.
McSteve is offline   Reply With Quote
The Following 2 Users Say Thank You to McSteve For This Useful Post:
fulmar2 (01-29-2013), vsheetz (06-12-2011)
Old 06-08-2011, 11:19 AM   #7
Electrical Contractor
jbfan's Avatar
Rewards Points: 650
In the first picture, that bars looks to be moved more to the right side of the panel.
That bar is used to prevent breakers from being installed behind the main breaker.
Old 06-12-2011, 03:10 PM   #8
Thanks all to explaining and pointing out what needed correction. Today I moved the main breaker and implemted the hold-down - so it is now as it should be.
I learn something every day from this most excellent forum!
____________
Vince
Heating question on main panel breaker, 15A viper Electrical 5 04-04-2011 07:31 AM
Main Circuit Breaker Test lthomps222 Electrical 16 11-07-2010 04:40 PM
Murray main lug center - what type of tandem breaker? cl or ncl? plove79 Electrical 4 09-01-2010 08:08 PM
This doesnt seem right. JoulesWinfield Electrical 27 07-26-2009 07:40 PM
Help! I broke my main disconnect breaker kosherdill Electrical 7 02-01-2009 08:23 AM
