Back Stabs - Electrical - DIY Chatroom Home Improvement Forum
Old 10-28-2013, 12:09 PM   #1
Rewards Points: 5,974
Back stabs
Are there any states where by code you cannot use the stab ins on the back of switches and receptacles?
Old 10-28-2013, 05:05 PM   #2
Rewards Points: 774
In my world 50, in the real world I have no idea but the spring loaded ones are typically a problem. If you have the screw clamp devices you are home free.
Know A Little is offline   Reply With Quote
Old 10-28-2013, 07:51 PM   #3
joed's Avatar
Rewards Points: 12,852
Screw clamp devices are called back wired.
Push in ones are called back stabbed.
Old 10-28-2013, 08:16 PM   #4
MarginallyQualified
Rewards Points: 2,464
I doubt it. Know why? They pass UL.
How can that be? Because when used as the instructions say... they're fine.
As good as or better than the X method or Y method?
For the application? Installed as instructed? Or just slapped in without regard?
Old 10-29-2013, 05:32 AM   #5
JOATMON
ddawg16's Avatar
Rewards Points: 1,810
I've only had trouble with a back-stabbed outlet once. That was enough for me to never do it again.
In fact, all of my outlets now have pigtails and are wired using the screws. It takes a little longer...but I worry a whole lot less.
Old 10-29-2013, 05:39 AM   #6
Cruising into the sunset
JulieMor's Avatar
Rewards Points: 518
I would first of all ask why you would do an electrical installation that has proven to be inferior?
JulieMor is offline   Reply With Quote
Old 10-29-2013, 06:05 AM   #7
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
That is simply a false statement without any real proven data, otherwise no manufacture would keep producing a product that would put their name on the line….
The Following User Says Thank You to stickboy1375 For This Useful Post:
Know A Little (10-29-2013)
Old 10-29-2013, 06:06 AM   #8
E2 Electrician
You cannot use #12 with backstabs, but I see no reason why you shouldn't use back stabs on #14 if you so wish.
Old 10-29-2013, 10:01 AM   #9
Let me clarify a little I have had a lot of calls of lights flickering or plugs not working that have been traced to back stabs coming loose. I don't use them, but kind of got into a argument about them the other day and I said I thought I had read where some areas had code that did not allow their use.
Thank you all for your responses.
Old 10-29-2013, 12:54 PM   #10
MarginallyQualified
...lot of calls of lights flickering or plugs not working
That's called an anecdote. It describes a correlation but not a causation.
Dig deeper to see what *else* was going on with those jobs; in particular the work quality of the rough-in and later the trim. I'll take a wild guess and say they were high volume, lots of rookie helper labor tract houses.
Old 10-29-2013, 05:56 PM   #11
JulieMor's Avatar
Rewards Points: 518
Every municipality I've worked in since about the mid-90s has outlawed the use of the back stabs. There's a reason for that.
As far as the manufacturer goes, I wouldn't place a lot of stock in that. It's easy to blame something else, like the person who did the installation. But I do know the old back stab receptacles I used to see years ago are harder to come by. So maybe the manufacturers are doing something about it too.
Old 10-29-2013, 07:13 PM   #12
Rewards Points: 774
First I am no fan of back stabbed devices but in my experience most local codes are instituted based a personal dislike, prejudice or dreams of greatness.
The Following User Says Thank You to Know A Little For This Useful Post:
stickboy1375 (10-29-2013)
Old 10-29-2013, 08:06 PM   #13
Rewards Points: 6,652
In those builds, where they are paid by the room or structure, it is quicker to just poke the wire into the back, then do it right, by cutting the insulation, making the loop and screwing down.
Really if you are using Commercial outlets and switches, which have a compression plate that is screwed down, using a "Yankee" drill makes it quicker to tighten the screws on those, then it does to hand twist the screw, and is just as fast as "Backstabbing".
Old 10-29-2013, 08:10 PM   #14
E2 Electrician
Here is a perfect way to install a receptacle if you don't use the LEGAL back stab option, purchase a torque screwdriver, set to the manafactures specifications, tighten the screw to this method, otherwise, you are just as much a hack as the guy back stabbing… just saying.
Gac66610 (10-30-2013)
Old 10-29-2013, 08:17 PM   #15
Rewards Points: 774
I have not seen a Yankee in years and someone stole mine out of the office, Mine still had a wood handle, not plastic like the last ones I saw for sale in the hardware stores.
Someone will ask
http://www.traditionalwoodworker.com...fo/500%2D0526/
The original Yankee was manufactured by Stanley.
Back filling a hole in lawn Master Brian Landscaping & Lawn Care 2 06-22-2013 11:47 AM
To back butter or not to back butter? fpr4 Tiling, ceramics, marble 54 05-13-2013 03:18 PM
Sump Pump Discharge and drain Back dukeboy633 Plumbing 7 04-26-2013 01:19 PM
Detached Garage Subpanel + Generator Back Feed insaneirish Electrical 3 09-06-2011 02:09 AM
Re-shaping back yard, tilling and other questions fox_forma Landscaping & Lawn Care 12 03-15-2011 04:51 AM
