Back Stabbing ? - Electrical - DIY Chatroom Home Improvement Forum
Old 09-16-2013, 08:26 AM   #1
Rewards Points: 240
back stabbing ?
i see references as to NOT backstab wire into the device. what is so bad about this ?
Fix'n it is offline   Reply With Quote
Old 09-16-2013, 08:28 AM   #2
PoleCat's Avatar
Rewards Points: 1,652
Poor electrical contact.
"Ask me anything. If I don't know the answer I'll make something up."
PoleCat is offline   Reply With Quote
Old 09-16-2013, 08:37 AM   #3
Rewards Points: 240
aah, gotcha. would it be ok for low power lighting ?
Old 09-16-2013, 08:56 AM   #4
PoleCat's Avatar
I installed a bunch of outlets and switches in my house when we first got it and back stabbed all of them and non of them ever failed in 20 years. But logic dictates that the circle of wire and the screw is far better so that is what I practice now. Unfortunatly I have stabbed myself in the hand much more with the screwdriver since doing it this way but that's my fault. Also I have since replaced all the old 14 gauge wire with 12.
The Following User Says Thank You to PoleCat For This Useful Post:
Fix'n it (09-16-2013)
Old 09-16-2013, 01:20 PM   #5
I have quickly become a fan of the type of outlet that accepts a straight section of wire (like a backstab) but has a screw to secure the connection.
BTW...I ran across some backstab failures while working on a relative's house.
oberkc is offline   Reply With Quote
Old 09-16-2013, 02:05 PM   #6
joed's Avatar
Rewards Points: 13,762
Those are called back wired.
The Following User Says Thank You to joed For This Useful Post:
oberkc (09-16-2013)
Old 09-16-2013, 07:43 PM   #7
dmxtothemax's Avatar
Rewards Points: 5,610
In the interest of long term reliability, most electricains prefer
not to use backstab for anything.
That includes low power lighting.
dmxtothemax is offline   Reply With Quote
Old 09-16-2013, 07:50 PM   #8
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
sublime2 is offline   Reply With Quote
Old 09-16-2013, 09:07 PM   #9
kevinp22's Avatar
Rewards Points: 252
Back Wired - Very Reliable (GFCI rec and WR receptacles typically have these)
Back Stab - Not no much, but legal to use
kevinp22 is offline   Reply With Quote
Back filling a hole in lawn Master Brian Landscaping & Lawn Care 2 06-22-2013 11:47 AM
To back butter or not to back butter? fpr4 Tiling, ceramics, marble 54 05-13-2013 03:18 PM
Sump Pump Discharge and drain Back dukeboy633 Plumbing 7 04-26-2013 01:19 PM
Re-shaping back yard, tilling and other questions fox_forma Landscaping & Lawn Care 12 03-15-2011 04:51 AM
Power goes out in back room & on by it's self!! happy_4_now Electrical 2 11-23-2010 06:09 PM
