Old 03-22-2008, 09:49 PM   #1
back to back outlet box
I have a single family dwelling with interior sheet rock walls. I am going to install a new outlet box on the backside of a wall that currently has an outlet box. What is the code requirement as to the location of this new outlet box? Can it be installed within the same stud cavity? A minimum distance requirement from original existing box?
Captflx is offline   Reply With Quote
Old 03-22-2008, 10:00 PM   #2
Electrician
It will be fine unless its some type of firewall...
chris75 is offline   Reply With Quote
Old 03-22-2008, 10:53 PM   #3
joed's Avatar
There is no code restriction about receptacle boxes on opposite side of wall.
There could be fire code regulations if this is a garage fire wall.
Old 03-22-2008, 11:03 PM   #4
Licensed Electrical Cont.
Speedy Petey's Avatar
Anyone ever see those 4.5" deep open back to back boxes?
By "open" I mean the one box is open to both sides of the wall.
Old 03-22-2008, 11:17 PM   #5
The current outlet box is in a bedroom and the ajoining wall is a hallway. By the answers here, I can put 2nd box in the hall wall in the same wall stud cavity as the bedroom outlet without violating an electric code.
Old 03-23-2008, 08:11 AM   #6
Electrician
Yes, I've used them also...
Old 03-23-2008, 08:32 AM   #7
Thanks to all who helped.
Old 03-23-2008, 09:41 AM   #8
When is fishing season?
CowboyAndy's Avatar
Don't forget that if your code requires arc fault breakers, you will have to add one at this point to be code compliant... that is if you don't have one already.
I DON'T OWN MY HOUSE...
MY HOUSE OWNS ME!
CowboyAndy is offline   Reply With Quote
Old 03-23-2008, 11:49 AM   #9
J. V.'s Avatar
He does not have to install an AFCI breaker to install an extra convenience receptacle. AFCI's are required in new construction and additions to existing structures.
Old 03-24-2008, 06:34 AM   #10
CowboyAndy's Avatar
If you alter a circuit, then the circuit must meet current code.
MY HOUSE OWNS ME!
Just for fun Andy in ATL Electrical 56 10-20-2009 10:33 AM
Adding new ceiling light in place of switched outlet XavierG35 Electrical 2 02-13-2008 10:05 PM
Wiring a switch, power from outlet Big Bill Electrical 4 09-15-2007 04:59 PM
Adding garage outlet Shane Electrical 1 02-23-2006 05:43 PM
European 220V outlet "Schuko" estophile Electrical 6 08-27-2005 09:45 AM
