AWG Wire Discussion - Electrical - DIY Chatroom Home Improvement Forum
Old 04-15-2010, 07:37 PM   #1
AWG wire discussion
Im sure the wire size drops again at the light fixture it self. In some cases you can drop a 20 amp branch circuit to # 18 with-in so many feet from the fixture.
voltech is offline   Reply With Quote
Old 04-15-2010, 07:42 PM   #2
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
I wouldn't bet on the 18 but regardless what size wire is allowable, that is only in some very strict situations. It's not a great idea to toss out unique allowances for general work. It tends to confuse the natives.
The Following User Says Thank You to nap For This Useful Post:
Jim Port (04-15-2010)
Old 04-15-2010, 07:46 PM   #3
Master Electrician
Rewards Points: 3,920
Show us 'some cases' please.
brric is online now   Reply With Quote
Old 04-15-2010, 07:51 PM   #4
The light fixture wiring is not part of the circuit
Taps....aaaaaaaaaahhh
Old 04-15-2010, 08:11 PM   #5
nap
You talking to me?
nap's Avatar
actually manufactured whips can be undersized. I would have to hunt up the sections that allow and control them but this is only for pre-manufactured whips that are listed for the specific use.
Old 04-15-2010, 08:20 PM   #6
From the switch to the fixture? Or just at the Fixture?
Old 04-15-2010, 08:26 PM   #7
Master Electrician
In any case, they are not branch circuit conductors.
Old 04-15-2010, 08:38 PM   #8
nap
You talking to me?
nap's Avatar
actaully they are. They would go from the last junction box to the fixture. They are branch circuit conductors.
Old 04-15-2010, 08:43 PM   #9
Not to get off topic but..
Actually there are many places a circuit can drop in wire size to as low as a #18
Old 04-15-2010, 08:47 PM   #10
Master Electrician
Branch circuit conductors end at the outlet, which is the junction box.
Old 04-15-2010, 08:48 PM   #11
You said "AT" the light fixture.....
Are you confused now as to what you meant ?
Or just trying to change what you meant ?
Old 04-15-2010, 09:05 PM   #12
No Im not confused sorry if it seems so. I did say at the fixture. My overall point is that light fixture wiring to my understanding is part of the circuit in some cases. Nothing more..
however, my question remains the same
Old 04-15-2010, 09:31 PM   #13
nap
You talking to me?
nap's Avatar
Oh, so the whip I make up has absolutely no limitations? I can run #16 in some FMC on a 20 amp circuit and I'm good to go?
you go argue with your inspector about it.
Old 04-15-2010, 09:34 PM   #14
Master Electrician
You sure could for fixture whips, not branch circuit conductors. Read the definition of a branch circuit.
What size conductors do you think come in a manufactured troffer whip?
Old 04-15-2010, 09:37 PM   #15
nap
You talking to me?
nap's Avatar
so, you are saying there are no limitations for things like a motor wiring where I run a whip from a j box to the peckerhead? I mean after all, the junction box is where the branch circuit conductors end, right? and then obviously I can run #24 wire from a junction box to a light fixture? right?
you are really missing something there brric.
Fanimation ceiling fan question: no blue wire from ceiling camrn2006 Electrical 8 03-07-2010 12:19 AM
HALP! Master/Remote Dimmer troubles! Confuserated Electrical 9 02-12-2010 03:30 PM
Burial wire and a seeming difference of opinion... SxS Electrical 19 02-24-2009 09:16 AM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 09:41 PM
Stranded wire on screw connections BigJimmy Electrical 7 01-19-2008 02:42 PM
