-   -   awg size for 60' underground line from house to shed for 60 amp (http://www.diychatroom.com/f18/awg-size-60-underground-line-house-shed-60-amp-73226/)
capslock 06-09-2010 09:15 AM
problem:
I have a shed that is about 50 feet away from the house, and about 60 feet away from the main circuit breaker. Currently UF-B 14/2 with ground underground cable is drawn from the circuit breaker to the shed, while 12/2 is primarily used in the shed.
I'd like a subpanel in my shed for 60 amps. This way I could have a couple 20 amp recepticals for my saws, 15 amps for my lights, and have room for 220v 20amp lines in the shed for my compressor and perhaps a future 220v upgrade of my table saw.
Now I know I can't do that with the current setup.
Questions:
1) What size awg would I use for the underground wire? Typically I know 60 amps require 6 gauge but does this still apply for 60+ feet? I cant seem to make sense of this issue.
2) does underground cable support higher amp rating than interior cable? I can't make sense as to why the prior owner ran 14/2 underground then in the shed used 12/2 for all the recepticals and lights.
Scuba_Dave 06-09-2010 09:22 AM
With 14-2 you can only have a 15a breaker, doesn't matter if its UF
For 60a use #6 TWHN in conduit
capslock 06-09-2010 09:40 AM
yep, i know. I noticed that the 14-2 is plugged into a receptical which is then wired to a 20amp breaker. I will be fixing this.
What size conduit? How much air space should there be for the cable inside the conduit?
So if I understand you right, you are saying to buy the following:
50' #6 black
50' #6 red
50' #6 white
50' #6 green
Fit all into one conduit (again, what size is appropriate?), then feed conduit from circuit breaker to sub-panel.
yes?
Scuba_Dave 06-09-2010 10:02 AM
You don't need the red, it can be black with red tape to mark it
Neutral must be white, #6
Green can actually be #10
If it is a straight run withoput any bends & twists I could use 1" grey electric PVC
I had 4 bends & still used 1" for my feed
Detached structure you also need (2) 8' ground rods
Neutrals & grounds not bonded together at the sub
Neutral bar not grounded to the case
I used a 100a 20 space main breaker panel as my sub & fed it with a 60a 240v breaker in the main panel
J. V. 06-09-2010 10:18 AM
Search "Sub Panels" "wire shed" "garage" ect..... in the search function of this forum. This is by far the most commonly asked question.
secutanudu 06-09-2010 10:31 AM
Lots of info in this sticky post too.
