I'm installing an automatic transfer switch for a standby generator, and I have a couple of (more) questions.
1) Do I need to pull the individual ground wires (bare copper) from the main panel and attach them in the transfer switch panel? I believe this is unnecessary.
2) Do I need to pull the individual neutral wires (white) from the main panel and attach them in the transfer switch panel? I think this is necessary, but I can't seem to come up with a solid reason as to why.
I've attached a diagram from the transfer switch manual. Thanks.
1) Yes you do or how else do you plan on grounding the transfer switch?
1) From what it looks like your transfer switch is also a panel built into it. So if your going to run your legs over to the breakers on the transfer switch you might as well bring the neutrals over as well.
But the neutral bus in the transfer switch is connected to the neutral in the main panel. Or are you referring to code requirements? Thanks.
Related Threads
DIY Home Improvement Forum
3.1M posts
319.5K members
Since 2003
