Automatic Closet Lights - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-08-2007, 11:28 AM   #16
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,874
http://www.google.com/search?hl=en&c...0S&btnG=Search
Then use any N.C. alarm contact to break the circuit when the door is closed.
I use Edwards 44 rolling ball contact switches.
Old 06-12-2008, 09:08 AM   #17
I found this forum and the relay is slick. Any suggestions on the magnetic switch? I need a rececessed one, not a roller ball. The problem I keep running into is that when they close the door the light comes on.
I keep asking for a Normally closed contact and I get a n-o with a closed loop, or a normally closed with an open loop.
*ACK*
haileysmom97 is offline   Reply With Quote
Old 06-12-2008, 05:06 PM   #18
Electrician
*ACK*
These are the exact ones I use... grisk.com
chris75 is offline   Reply With Quote
Old 01-20-2009, 11:02 AM   #19
Rewards Points: 150
Dang, what's the part number?
harleysilo is offline   Reply With Quote
Old 01-20-2009, 12:01 PM   #20
Electrician
ctsmiths's Avatar
Rewards Points: 150
Here is a surface mount that might help http://www.smarthome.com/7113/Door-a...0-White/p.aspx
ctsmiths is offline   Reply With Quote
Old 01-20-2009, 01:41 PM   #21
Tool Geek
PaliBob's Avatar
Rewards Points: 2,160
Here is another link to Speedy's Edwards Door Jamb Switches
Door Jamb Switches
Disclaimer
& Stay Safe
.....Bob Lavery
Old 01-20-2009, 01:41 PM   #22
I used one of these from my junkbox.
http://upload.wikimedia.org/wikipedi...icroswitch.jpg
No relay needed.
Old 01-20-2009, 02:19 PM   #23
Tool Geek
PaliBob's Avatar
Originally Posted by Yoyizit View Post
I used one of these .........
No relay needed.
Yoyzit, These are line voltage rated. Did you use it for a closet Light?
If so please post a pic.
Disclaimer
& Stay Safe
.....Bob Lavery
Old 01-20-2009, 03:35 PM   #24
Rewards Points: 150
I'm looking to do this on my new Pantry/laundry room, bi-fold louvered doors, old pull chain lights, don't want to run 110 down the walls and no place for big switch. Don't understand all of the options here.... http://www.grisk.com/parts.htm
Old 01-20-2009, 03:40 PM   #25
Rewards Points: 150
I don't fully understand the normally closed stuff either.... this comment above is confusing to me.... "I keep asking for a Normally closed contact and I get a n-o with a closed loop, or a normally closed with an open loop. " Which is it, or is it just a Normally closed one like this.... http://www.smarthome.com/7113/Door-a...0-White/p.aspx
Old 01-20-2009, 06:15 PM   #26
Tool Geek
PaliBob's Avatar
For these magnetic switches that are used typically for window alarms. N.C. refers to how it looks in the circuit i.e. the window is closed so the switch is closed. The Switch is closed because the matching magnet closes the switch.
When the widow is opened the magnet moves away from the switch so the switch opens.
Out of the circuit, when measuring this NC switch with an Ohmmeter, the meter will show Open until actuated by the magnet.
These are still only Low Voltage switches. Not to be used at line voltage.
Disclaimer
& Stay Safe
.....Bob Lavery
Old 01-20-2009, 07:24 PM   #27
Electrician
You got that ass backwards bud, a normally closed switch is just that normally closed, apply the magnet and it opens. Exactly why you need normally closed switches for a closet, so when you close the door the switch opens and turns off the light.
Old 01-20-2009, 07:27 PM   #28
Yeah, for a closet containing only dishes, but I have a bunch of exposed 25w bulbs vertically mounted for the lighting, so I should replace them with a flourescent one of these days.
Use the switches from earlier in this thread made for this application unless it's a lot of remodeling for you. I already had the switches and heatshrink tubing so I did what was convenient.
Clothes, or flammable material, or material that thermally insulates, stored in a closet with exposed bulbs is bad. I guess you could go with a boatload of 1w LEDs, but they are kind of directional.
When I was but a young lad, at camp I got my socks wet so I wrapped them around an incand. bulb to dry them.
Unfortunately, there was then a big commotion outside (people were swimming in the dark in water containing snapping turtles) so I forgot about my arrangement.
The whole cabin, and maybe some trees, could have burned down; the still-working lamp had lumps in the glass and my socks were literally toast.
Old 01-20-2009, 08:41 PM   #29
Tool Geek
PaliBob's Avatar
You got that ass backwards bud,.....
It would help if I checked for Brain in gear before I drove off the cliff.
Disclaimer
& Stay Safe
.....Bob Lavery
Old 01-20-2009, 09:34 PM   #30
Electrician
Hope I didnt sound cruel...
help with christmas lights!!!!! reds_21 Electrical 11 11-28-2007 11:02 AM
Musty smell from closet after leak Musty General DIY Discussions 2 09-10-2007 09:36 PM
Formula for changing lights to recessed bulbs? Jemo Electrical 12 01-26-2007 06:02 PM
Want to build closet in attic. Need advise. mbrittb00 Building & Construction 1 11-14-2006 07:58 PM
