Old 12-04-2007, 11:08 PM   #1
Automatic Closet Lights
I have several closets in my house with pull chain lights in them. They get left on all the time. I would like to install door jamb switches in them. I have seen the normal push button type switch, and also a roller ball switch, but I cant find a magnetic switch.
I don't want the push button kind because you have to install it on the side of the jamb. It would be a lot easier to drill a hole from above with a long drill bit, and install a roller ball, or magnetic switch. I think a Magnetic switch would be a lot nicer because you could flush mount it, but the only one I can find is for alarm systems.
Does anyone know about any magnetic light switches out there?
Sav505 is offline   Reply With Quote
Old 12-04-2007, 11:30 PM   #2
ICF Construction
Couldn't find anything magnetic
How's your humor level tonight? This is the best I could come up with...must wear sunglasses
Chris
Chris Johnson is offline   Reply With Quote
Old 12-04-2007, 11:52 PM   #3
Haha! The closets are way too small for that! But it might not be a bad idea to get an inexpensive one and put one regular bulb in it....Hmm
The one I attached was my original idea, but it's $30. I think a jamb switch would be better for the money.
Old 12-04-2007, 11:56 PM   #4
ICF Construction
Jamb switches I know of require you to remove the trim, some drywall run a wire, patch it all up and paint. I use the $ 30.00 sensor. Actually HD has a cheap one for around $ 9.00, Not the greatest but if it works, great, if not hey it's HD they take back everything
Chris
Old 12-05-2007, 01:11 AM   #5
" Euro " electrician
frenchelectrican's Avatar
speaking of closet luminaires the codes are very strict with this no open indscent bulbs in the clothes closet allowed you can add a motion switch when someone open the closet or use the door jamb switch one of the two will work good with it.
Merci, Marc
Old 12-06-2007, 12:44 AM   #6
UAW SKILLED TRADES
Stubbie's Avatar
How about this closet light relay and a set of magnetic contacts at the door instead of the jamb switch.
http://www.tequipment.net/RemconRC-120S.html
The Following User Says Thank You to Stubbie For This Useful Post:
electures (12-28-2012)
Old 12-07-2007, 07:31 PM   #7
door jam switches require femoving the door frame and cuttin dry wall i recomend as others have the sensor on the light
wiredog is offline   Reply With Quote
Old 12-07-2007, 08:15 PM   #8
Electrician
That was my idea!!!! I've been doing that for years!
chris75 is offline   Reply With Quote
Old 12-07-2007, 08:54 PM   #9
UAW SKILLED TRADES
Stubbie's Avatar
Yep it's a pretty slick way to go. Speedy Petey showed them to me about 3 years ago.
Old 12-07-2007, 09:05 PM   #10
The relay is a great Idea, but on the web site they are $37.15. I think I would would be better off with the $29 motion sensor. I have 6 closets that I would like to do this in, so I don't want to spend too much money.
I was thinking that with a magnetic switch, I would be able to go through the top of the jamb straight into the attic with a long drill bit.
I just found thesehttp://www.hamiltonsensors.com/glpca...=4719_4720&p=2
I wonder if they would work.
Old 12-07-2007, 09:44 PM   #11
Electrician
The magnets will only work if they are NC (normally closed) magnets, otherwise the light will come on with the door closed instead of the door open.
Old 12-07-2007, 09:46 PM   #12
Electrician
I use them in Progress Fluorescent lights, (P7008-30) They work very well together.
Old 12-07-2007, 09:52 PM   #13
UAW SKILLED TRADES
Stubbie's Avatar
Great I'll file that away....
Old 12-08-2007, 07:29 AM   #14
Licensed Electrical Cont.
Speedy Petey's Avatar
The problem with an occupancy sensor is where to put it. If the closet is small and the sensor is inside it may not sense you as you are 180 deg and behind from the sense area.
For large walk-in closets they work fine.
With that relay NO damage or repair is needed. You can put the ball contact in the top or side jamb and snake the lo-vo wire up to the attic quite easily.
Heck, I can typically put in a line-volt jamb switch with no damage at all also. They can be done "old-work".
Old 12-08-2007, 10:55 AM   #15
This relay and ball contact system sound like just what I need also! Got a link to the parts needed to complete this install from scratch?
Troubleshooter is offline   Reply With Quote
help with christmas lights!!!!! reds_21 Electrical 11 11-28-2007 11:02 AM
Musty smell from closet after leak Musty General Discussion 2 09-10-2007 09:36 PM
Formula for changing lights to recessed bulbs? Jemo Electrical 12 01-26-2007 06:02 PM
Want to build closet in attic. Need advise. mbrittb00 Building & Construction 1 11-14-2006 07:58 PM
