-   -   Auger or bore? (http://www.diychatroom.com/f18/auger-bore-23548/)
fw2007 07-12-2008 08:48 AM
Auger or bore?
Hi;
I have been using mainly wood boring bits for holes from 1/2 to 3/4".
Would an auger bit be faster than the flat wood bore?
FW
jrclen 07-12-2008 08:53 AM
Originally Posted by fw2007 (Post 138342)
Hi;
FW
I use the flat bits because they are cheap. I use a powerful drill to hog the holes out quickly. When the bit gets dull from hitting nails, out it goes.
fw2007 07-12-2008 10:55 AM
Unfortunately, all I have is an old Craftsman 3/8" hand held corded drill.
It works, but isn't powerful enough for tough jobs, so it takes me a very long time to finish such jobs.
I am just a DIY'er, not an electrician, so what work I do is bits and pieces.
It would be nice to have a "real" drill, but currently my budget cannot afford it.
I had been using a long-shaft 3/4" flat bore, but I dulled it when I hit brick while drilling up from a crawl space.
I like the long shaft bits rather than using an extension, because the set screws in the extension are always loosening up.
Yesterday, I ruined my old foot long 1/4" extension when I tried to tighten the set screw and the head stripped out. Now I have to drill it out to remove the bit that is stuck in the thing.
I also found that most of the newer wood boring bits (flat) will not fit my 1/4" extension due to the "knob" at the end of the shaft. As I am sure you know, these bits are intended for quick release chucks, that's why they have the extra nub at the end.
I should probably purchase a quick-release chuck adapter. I believe I can get one at HD for a few bucks.
FW
J. V. 07-12-2008 12:14 PM
I prefer auger bits. They last forever and are so much faster. No pushing needed as it pulls itself through the material. Only down side is that they are a bit longer than the spade bits and more expensive.
nap 07-12-2008 12:55 PM
I have fallen in love with these bits.
If I remember, the set was about $25 so they are not expensive so if damaged beyond repair, not a big loss and they bore faster than any other bit I have ever used.
well, not sure the link is working so here is a pic:
http://www.irwintool.com/irwin/consu...3041006_lg.jpg http://www.irwintool.com/irwin/consu...ges/spacer.gif http://www.irwintool.com/irwin/consu...ges/spacer.gifhttp://www.irwintool.com/irwin/consu...ges/spacer.gifhttp://www.irwintool.com/irwin/consu...ges/spacer.gifhttp://www.irwintool.com/irwin/consu...ges/spacer.gifSpeedbor MAX Spade Bit Sets http://www.irwintool.com/irwin/consu...ges/spacer.gifhttp://www.irwintool.com/irwin/consu...ges/spacer.gif http://sanfordcorporation.112.2o7.ne...hp=N&[AQE]
BigJimmy 07-12-2008 04:16 PM
Originally Posted by nap (Post 138409)
Got this exact set recently from my father in-law. Gotta agree w/ the Napster, they are totally deluxe. I have found in general that Irwin's products are all pretty much the cat's a**.
Yoyizit 07-12-2008 04:44 PM
auger bits. . .
require less torque from your drill than flat, paddle-drill bits, so you should get more drill motor life with augers.
junkcollector 07-12-2008 05:29 PM
Originally Posted by Yoyizit (Post 138477)
auger bits require less torque from your drill than flat, paddle-drill bits, so you should get more drill motor life with augers.
I have to disagree with that statement. I have several larger auger bits, all above 3/4". Nothing but my powerful 10 amp 1/2" drill has enough power for them. I can bore up to 1-1/2" with a woodboring spade bit and a 3/8" electric drill.
Yoyizit 07-12-2008 05:54 PM
I have to disagree
Assuming your 3/8" drill delivers less torque than your 1/2" due to gearing and motor size, these results puzzle me.
The drill motor owner's manual usually says something about the maximum drill bit dia. recommended, and I wonder if this contradicts their recommendations.
I haven't measured the current demanded by a drill using different bits, but one bit screws into the wood [like it's always cutting with the grain] and the other scrapes away the whole circle [across the grain].
Seems like this second option takes more work because more wood is pulverized, rather than a long, curly "chip" being created.
I guess the other factor is how deep/how fast does each drill bit go and that should depend on motor hp and the torque delivered.
wire_twister 07-12-2008 09:57 PM
I agree with junk collector, I can use my cordless drill in hi speed with the paddle bit. but have to get in low gear for the auger bits. I think this is because the augers feed screw is pulling the cutter in keeping up feed pressure where as you can vary the pressure on a paddle bit according to the woods hardness.
fw2007 07-12-2008 09:58 PM
Very interesting, and helpful. Thanks guys.
I'll take a look at my local HD on Monday.
I will need a bit with at least a 1 foot shaft though. This might require me to replace my old extension.
I would be willing to spend a bit more $$ if it will make the job easier. I have several holes to drill.
FW
Speedy Petey 07-13-2008 07:31 AM
100% agree.
Auger bits are all about torque.
Spade bits are all about speed.
Yoyizit 07-13-2008 09:05 AM
augers, spades, torque. . .
Yet another perfectly good theory shot down in flames!
jrclen 07-13-2008 09:30 AM
I wish you guys were all closer. I am starting a job Monday which would give everyone a good test for their favorite drills and bits. All the plaster and lath has been removed from a 140 year old house in town. It features full size oak studs and joists. And knob and tube throughout. I bought 4 new spade bits Friday to get me started. I bet one of those bits Nap showed us might work good in this application.
Yoyizit 07-13-2008 10:28 AM
Originally Posted by jrclen (Post 138640)
. . .a good test for their favorite drills and bits. . .
Corded vs. cordless is another variable in this experiment. A wall outlet equals a battery with unlimited amp-hour capacity.
